Ignition
Old Mar 17, 2025 | 04:50 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
In the 60's and 70's getting a film of oxidation on a set of points particularly on a vehicle that was parked up for several months at a time was extremely common.
Working on motorcycles and snowmobiles that both had there off seasons I ran into this often.
if the points don't ground the coil wont build up. The spark accurs when the points open. Losing the ground. But if the points never ground the coil will never build voltage. (Dwell).
so, to say the material that contact breaker points are made of never corrode? Sorry, I generally do agree with Lars.
But not on this one.
Next they'll be saying they never burn or get pitted .
The reason to switch over to a electronic ignition system is the same reason all the factory's did back in the 1970's. Less maintenance.
Old Mar 17, 2025 | 07:53 AM
1860army's Avatar
1860army
I remember fixing my buddies boat that had some sort of 4 cylinder car motor with points, dressed the points with a points file and set the gap with a match book cover... Ran fine until he forgot to put the plug in it....LOL...he still does that type of stuff 40 years later!!!
60
Old Mar 17, 2025 | 10:23 AM
Gold Dragon's Avatar
Gold Dragon
If you do decide to go with an upgrade to your ignition and change out the distributor, pay attention to hood clearance issues. A typical Chevy distributor may be too tall.
Old Mar 17, 2025 | 12:40 PM
forman's Avatar
forman
so adjusting the points every 10k miles is too much work?
for some reason it always happens at the most in opportune time
Old Mar 17, 2025 | 04:55 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
every spring when I get my car ready I glance over all suspension bolts and parts change oil and check fluids and get the dwell meter out. It doesn't take long to check it.
Old Mar 18, 2025 | 01:54 AM
7T1vette's Avatar
7T1vette
You can swap to a Pertronix system rather easily. But, they are not as inexpensive as they once were. The main drawback to an aftermarket electronic ignition system is that WHEN it fails, you are "dead in the water". There is no 'limp home' mode. Call the tow truck.
Stock points system, on the other hand, will let you know when they are in need of maintenance or replacement. And you can still drive home to do the repair.
Worst problem with stock GM points system is that owners start messing around with "hot" ignition coils, etc and end up burning points or shortening their life considerably. I've got nothing against a good (stock) GM HEI system But you still can't drive home WHEN the module fails.
And, as Lars points out, a stock points system using quality parts that is adjusted properly will perform just as well as any electronic system on a stock engine.
Old Mar 18, 2025 | 05:56 AM
4-vettes's Avatar
4-vettes
Absolutely to all of the above
of course I have never had a module fail. Car is only 47 years old so it could happen one day. I had a coil drop dead once. I was less than a block from home. We pushed it the rest of the way. A coil dropping dead on any ignition system will leave you dead.
There is no perfect system. Although I personally have had very good luck with HEI Distributors . I currently run a DUI HEI in my Vette.
Oh, and there is no such thing as a taller GM Distributor. Don't know where that one came from, (above). All the replacement HEI distributors will fit, they may not fit under the factory chrome shielding. Then get the shielding for a 76 or77.
Old Mar 18, 2025 | 08:41 AM
Nowhere Man
I have had all types of GM ignition systems; points, HEI, opti spark, and coil pack. I have had points loose the dwell but it got me home, I had a module on a HEI fail in the drive way at 20* out side. Opti spark I think you all know how well they work . And the latest coil pack I had one give me an miss fire. I could get that home. But need a good scan tool to figure that out like you said there is not one great one that won't fail. It's how you can fix it and the availability of parts. The great thing about any GM ignition system is any auto parts store will have the parts you need in stock and can be fixed in less then an hour. Your one size fits most widgets your dead in the water until the mail man comes or you swap it back over
Old Mar 18, 2025 | 11:40 AM
Fwyflier's Avatar
Fwyflier
Just letting you guys know, zip corvette sells a dizzy that will fit under the shielding of the early vettes with an impulse that will works on a coil only system. In their description says their dizzy is the stock height and indicating it is the only one available while others won’t fit thus confirming that the aftermarket dizzy’s are slightly higher and won’t fit under the early shielding.
Old Mar 18, 2025 | 12:53 PM
1860army's Avatar
1860army
For those that think points are a better/more reliable option, that is only because we mostly work on our own cars and know how things work and can take care of things. But to your average Joe or Joey, electronic ignitions are infinitely better because they don't need attention unless they die. I grew up in New York during the 60s and 70s, driving down the highways leading out to LI you would see cars broke down on the side of road all the time, sometimes it looked like they were just parked, there were so many. Some over heated but many had ignition issues, bad wires, coils, points, voltage regulator points would stick. As we got into the 80s and 90s they became much fewer, because electronics work better and require less maintenance... and back in those days leaving your car on the belt parkway over night guaranteed that you would need new wheels and tires the next morning, maybe doors and more....LOL
60
