steering column question
Old Apr 27, 2025 | 10:33 PM
kevdart's Avatar
kevdart
Default steering column question
Hello everyone,
I when I bought my 78 corvette the steering column was taken apart. But I never could find out just why. One problem was the hazard light was stuck on. So maybe that was why.
However, the steering column feels loose and there is a good bit of play.
Is it normal to have such a loose steering column? Or will it go away when I put the column back together?
I uploaded a video of it on you tube:
If you don't want to use the link search for "1978 corvette steering column" It will be the one with a red interior
Thanks for the help guys
Kevin
Old Apr 27, 2025 | 10:46 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I cant help with your year car but something is def. loose or worn.
Old Apr 27, 2025 | 11:01 PM
C8H18's Avatar
C8H18
I agree - that seems sloppy and clunky. I bought a supposedly rebuilt TT column for early C3s that was either not rebuilt or done poorly - So I rebuilt it. It actually wasn't that bad. There some good detailed videos on YT but be sure and find one for late model specific C3 columns. I don't recall the exact year they changed from the early style to the late style but I'm sure yours is the late style.
I suspect over the years people often use the steering wheel for leverage as they enter/exit the car. A straight column may take this usage better but TT columns probably not and get loose over time...
Old Apr 28, 2025 | 09:38 AM
kevdart's Avatar
kevdart
Yes I think something is worn or not just right.
Old Apr 29, 2025 | 07:08 AM
69ttop502's Avatar
69ttop502
It appears the 4 bowl support bolts are loose. A very common problem. Only bad thing is it takes a good bit of disassembly, have to remove the bearing housing to get to them but an easy fix nonetheless. See paper below. Picture on page 5 labeled test fit shows the support bolts referenced.
File Type: pdf
Old Apr 29, 2025 | 10:05 AM
kevdart's Avatar
kevdart
Thanks 69ttop that's great info.
Where do you find papers 1 and 2?
Kevin
Old Apr 29, 2025 | 10:14 AM
69ttop502's Avatar
69ttop502
Away from the computer now but will post them for you later.
Old Apr 29, 2025 | 10:20 AM
kevdart's Avatar
kevdart
never mind just found them
Old Apr 29, 2025 | 09:33 PM
Mark G's Avatar
Mark G
That... or the side (hinge) pins are worn...
There's a handful of reasons why a guy would take a steering column apart.
Old Apr 30, 2025 | 11:17 AM
7T1vette's Avatar
7T1vette
Columns are repairable; but it will take some patience, time and effort. Jim Shea's papers are a MUST for doing such.
To steering column question
