Chrome plating_windshield header molding
Old Jun 23, 2025 | 11:20 PM
20mercury's Avatar
20mercury
Default good info thanks I just bought some 8-32 screws today
Originally Posted by Postal123
Mine has four 8-32 screws per molding piece; two aft and two forward. The two forward screws are the issue with windshield installed. Molding 'ear' inserts into center stainless piece and center stainless has 6 U-nuts on aft side to secure to header bar. The '68 appears unique in that the forward edge of center stainless is secured by upper stainless trim. I believe factory and most restorers use sealant where molding ear inserts into center stainless piece. Hope that clear.
Quote was from Atlas Chrome Plating in Houston. I received a cheaper quote from a place in CA but its electroless.
v/r,
Rob
Good info thanks I just bought some 8-32 ss screws today on a guess. Thanks.
I say yes you want to seal the joint you describe. If you look at the windshield sheet metal frame, there is a pocket under the upper corner molding that does not drain and collects water. Bad design I say, so we do what we can.
Old Jun 23, 2025 | 11:23 PM
Postal123's Avatar
Postal123
Originally Posted by ZIOGEO
$225 each?
What's the contact number of the person who quoted you that. I want to hire them to do mine
Yes $225 each. They quoted approx 3 weeks turn around. Atlas in Houston.
v/r,
Rob
