I recall reading somewhere in the past about notches in C3 wheel arches located at the 12 o’clock position of the inner lip. They were provisions for the body lifting apparatus used in the St. Louis plant during the body merge. I recall both my 69s having them and I was told that it was a good indicator that verified the fenders and quarters were originals, as replacements typically did not have the notches. My 73 does not have these notches on any of the wheel arch inner lips but also appears to have all the original undamaged SMC bodywork. Did the notches go away when GM switched to SMC around 73?
Thanks for your reply Allen and the picture of your 71s wheel arch inner lip. Yes, this is the notch(s) I’m referring to.
Anybody else have some knowledge on this? How about some of you guys with NCRS judging experience, did the notches go away at some time in the early 70s? If so, what year and why?
The '70-'72 judging guide (6th ed, pg 69) says:
Lips of the fenders are not cut to allow larger tires. A slight thinning of the front fender lip at two points rear of the center is normal. These were for factory assembly purposes. One is on center, the other is six inches toward the rear.
The photo on page 70 shows the notches much like Alan71 posted above. My '72 does indeed have these notches... funny I never noticed or remembered them over the last 35 years!
