Install new shocks??
Old Nov 4, 2025 | 09:06 AM
JavaJolt78's Avatar
JavaJolt78
Default Install new shocks??
Hey all I just bought a set of new Bilstein shocks for my 78 and would like to know B4 I source out the installation if I try and DIMS do the wheels have to be removed and do I need a lift??
JJ78
Old Nov 4, 2025 | 10:36 AM
SEVNT6's Avatar
SEVNT6
I did mine myself years ago in the garage...no lift & no big deal. You won't need to remove the front tires but the rears will need to come off...
Old Nov 4, 2025 | 10:38 AM
Tampa Jerry's Avatar
Tampa Jerry
The front shocks come out from the bottom, so you have to lift the front up well enough to get the old shock out and the new one in. Easier to be done on a lift, but in my younger days I did it all without a lift. I always jacked up the car to change the rears. without a lift I would remove the wheels just for the added room. Sounds like you are working in a limited space. May be best to farm the job out. It should not be too big of an expense. Any competent shop should knock the job out pretty quickly. Jerry
Old Nov 4, 2025 | 11:04 AM
bmotojoe's Avatar
bmotojoe
Pull one of the lower bolts of the front shock.
Go to your local hardware store and get a fully threaded bolt same thread pitch but about 1.5" in length and a flat washer. For me my strength just wasn't there to compress the shock and start the original bolt.
Thread the longer bolt in until you can start the original length bolt. R&R the longer bolt with the original.
Old Nov 4, 2025 | 12:46 PM
sunflower 1972's Avatar
sunflower 1972
Zip ties are your friend: https://www.corvetteforum.com/forums...all-trick.html
To Install new shocks??
