Stereo Update
Old Dec 17, 2025 | 09:10 PM
']['HRUS'][''s Avatar
']['HRUS']['
Default Stereo Update
Hello, I finally bought the car of my dreams. But there are some things that need to be updated. I recently installed a Power Acoustik CP-71WA head unit. I wanted a single DIN stereo but didn't really care for the ones with *****. I wanted to get a sleek look but try to make it look like it either came stock with the car, or looks like it should have come that way from the factory. I didn't want the typical stereo install that sticks out like every other car stereo. Those installs scream "aftermarket". The CP-71WA is all touch screen with tiny slivers of buttons on each side. But what sold it for me was the 4v peamp outputs because I intend to do a custom stereo install with seperates up front and a couple subs out back (I've owned all the equipment for about 30 years, some of it still in the boxes).
So I decided to build a recessed area so the head unit would be flush with the dash. Bought a sheet of ABS plastic and some ABS glue and went to work.
Test fit 1
Glue it together and test fit again
I think it's worth stating at this stage I was a nervous wreck. I meticulously cut that opening. MY GOD what a pain to cut it straight and not ruin it with an errant slip-up!
As you can see from initial install, the stereo is pretty close to flush with the front of the dash. I will admit that on the first go around, I actually forgot to account for the thickness of the dash, so I had to cut about an 1/8" from the recessed plastic tray I made before I glued it on.
And here is the final install. I think it looks really sharp, doesn't really ruin the aesthetics of the dash and nearly looks like it really belongs there.
Another cool feature of the CP-71WA is that it lets you have custom boot-up pictures and backgrounds.
This is the boot-up screen.
Old Dec 17, 2025 | 09:55 PM
zxryder72's Avatar
zxryder72
That is very, very cool. Perfect for the later C3 console set up.
Old Dec 17, 2025 | 11:42 PM
TorchZ51's Avatar
TorchZ51
Looks great, integrates nicely with the stock gauges.
Old Dec 18, 2025 | 02:30 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Looks really good. Nice job.
Old Dec 18, 2025 | 08:33 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Nice upgrade!
Old Dec 18, 2025 | 07:34 PM
drwet's Avatar
drwet
That's as nice as any I've ever seen. Congrats.
Old Dec 18, 2025 | 11:11 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Good job!
To Stereo Update
