Door panel velcro pieces
Old Dec 26, 2025 | 05:38 PM
Spot Rot's Avatar
Spot Rot
Default Door panel velcro pieces
The reproduction ones I've tested are made from a plastic that is too flexible. It takes a very small amount of force to separate them so they don't hold the door panel to the inside of the door.
Does anyone have a source for reproduction ones that hold tightly together are like the originals? Or any clever solution to hold the door panels tight to the door on the lower edge?
Old Dec 26, 2025 | 06:00 PM
forman's Avatar
forman
Those door fasteners don’t work and never have
Old Dec 26, 2025 | 06:20 PM
sphil's Avatar
sphil
Check out this thread, post #5, haven’t tried it yet but looks promising
https://www.corvetteforum.com/forums...lcro-pads.html
Old Dec 27, 2025 | 08:12 AM
Alan 71's Avatar
Alan 71
Hello SR,
Are you using the original or reproduction inside door card?
The reproduction cards are often 'warped' so they're difficult to mount securely.
Could that be part of your problem?
Regards....
Old Dec 28, 2025 | 08:39 AM
Spot Rot's Avatar
Spot Rot
Great responses, thank you.
I've also seen repro door panels that were warped. My current ones are OK.
The issue is that the repro velcro pieces are very weak and unlikely to hold even a perfect door panel. And yes the original velcro pieces were not perfect. Often, the little stalks have to be straightened out or they won't mesh and hold at all.
sphil: thanks for the post reference I'll try those.
I'm curious: what means of fastening worked well? Tip: if you want less holding power, place strips of electrical tape over the magnet.
Current pricing: mag daddy 97602$32/4 summit w/s
$35/4 amazon w/s
$49/10 ebay w/s
Best: $32/9 z w/s ($2.35 ea + $9s) zackelectronics.com
To Door panel velcro pieces
