Missing key
Old Jan 6, 2026 | 03:49 PM
60grit's Avatar
60grit
Default Missing key
Happy NewYear to everyone at CF!
A friend of a friend has been willed a 1974 (C3)
Corvette.
Unfortunately the key(s) can’t be found and car is locked.
Any suggestions tips, tricks, hacks on what can be done to get Corvette open and a replacement key.
Old Jan 6, 2026 | 03:50 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Call the guy (locksmith).
Old Jan 6, 2026 | 03:56 PM
60grit's Avatar
60grit
We discussed that, but was hoping someone
might have a trick up their sleeve.
Old Jan 6, 2026 | 04:13 PM
jcgunn's Avatar
jcgunn
Before you call the guy, search under the car for a hide-a-key.
Old Jan 6, 2026 | 04:14 PM
ricks327's Avatar
ricks327
If you have some road service available, such as AAA, give them a call that you have a lockout. A slim jim is used to get into the door panel from the outside. Then remove the ignition lock and door panel for removing the door lock. Then take them to a locksmith.
Old Jan 6, 2026 | 05:05 PM
60grit's Avatar
60grit
Nice, solid ideas!
Old Jan 6, 2026 | 05:26 PM
DSOMC6's Avatar
DSOMC6
Hammer fist the top near where the latch is. If its not too tight, it will give and you can liftt the top off.
Coat hanger or something similar down between the window and the latch.
Old Jan 6, 2026 | 05:58 PM
SEVNT6's Avatar
SEVNT6
You could also buy a slim jim...
https://www.oreillyauto.com/detail/c...ol/pfm0/w1147c
Old Jan 6, 2026 | 06:31 PM
z06clif's Avatar
z06clif
The key is in the JUNK DRAW in the kitchen,next to that ball of rubber bands
Clif
Old Jan 6, 2026 | 07:49 PM
Bottlejunkie's Avatar
Bottlejunkie
Old Jan 6, 2026 | 08:26 PM
Easy Rhino's Avatar
Easy Rhino
You could post this question in the C3 section as well.
Old Jan 6, 2026 | 09:21 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
If either window is a little loose, this is an excellent idea. Might be able to jimmy up some kind of tool to slip in there.
Old Jan 6, 2026 | 10:11 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
There is another one that shows the inner working of the latch as well. I agree that you should "break" in with a slim jim or coat hanger......or pay a tow truck driver to get your door open and search the INSIDE for a spare key first before spending bucks on re-keying.
Old Jan 6, 2026 | 10:42 PM
Moved to C3 General for hopefully some assistance.
Old Jan 7, 2026 | 08:17 AM
CurtP's Avatar
CurtP
St. Jude Donor '25-'26
A locksmith will use a Lishi pick to decode the lock without causing any damage and will be able to cut a key by code. It's better than possible damage from someone trying to brute force their way in. Usually doesn't cost that much. Been a few years since I had it done but I think it was around $75 per cylinder. The key that came with my Porsche was so worn out that I couldn't get a copy made.
Old Jan 7, 2026 | 08:45 AM
60grit's Avatar
60grit
Thank You!
A lot of Great info, will pass this on to my friend
most of the info I would never thought of or knew
Will let you know what happens in a follow up.
Thanks Again
Old Jan 7, 2026 | 11:23 AM
CurtP's Avatar
CurtP
Old Jan 10, 2026 | 11:34 AM
68/70Vette's Avatar
68/70Vette
FYI: I once read a fascinating story about a guy who made a living stealing Corvettes from the C2 C3 eras. For C3s, he had a template made which he would align using the door-key entrance and door handle. There was a tiny hole on the template. Inserting an ice pick like tool through the template hole and then through the fiberglass skin. Thanks to the template, the end of the ice pick was aligned under a door latch lever. He'd just angle the pick up and the door would open. He had other fascinating techniques. He even took orders for Corvettes! He wrote the story of his career while he was in jail for car theft.
To Missing key
