Reinforcement
Old Mar 16, 2026 | 04:37 PM
jigoe007's Avatar
jigoe007
Default Reinforcement
Guys:
I can’t find GM part # 3976463-4 for a ‘69 coupe (reinforcement found in the assembly manual on page J133, F26, item #3).
Can I substitute a regular washer?
Old Mar 16, 2026 | 05:25 PM
MelWff's Avatar
MelWff
Are those two pictures actually related to one another.
This post refers to that part number but it is Not a washer.
Look at post 3.
https://www.corvetteforum.com/forums...kets-69-a.html
Old Mar 16, 2026 | 06:08 PM
robertea's Avatar
robertea
This is part number 3.
Old Mar 16, 2026 | 06:26 PM
MelWff's Avatar
MelWff
Correct, not a washer as the original poster thinks.
Old Mar 16, 2026 | 06:50 PM
jigoe007's Avatar
jigoe007
Sorry for the confusion.. It's the reinforcement that goes under the 7/16-20 jam nut.
Old Mar 16, 2026 | 07:17 PM
MelWff's Avatar
MelWff
The part that the red arrow is pointing to is NOT a washer, it's a metal reinforcement PLATE, held down by 3 bolts.
Old Mar 16, 2026 | 07:24 PM
MelWff's Avatar
MelWff
This is the reinforcement
Reinforcement
Old Mar 16, 2026 | 07:52 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Mel,
Not sure that what you posted is the reinforcement being referenced. The one you posted is the outboard reinforcement… The reinforcement in the A.I.M. drawing (3976463-4) is the inboard reinforcement.
Looks like this…
It is reproduced by CSC, but I can’t tell you how well it is done.
Regards,
Stan Falenski
Old Mar 16, 2026 | 08:08 PM
MelWff's Avatar
MelWff
Originally Posted by Rowdy Rat
Mel,
Looks like this…
Regards,
Stan Falenski
Either way it's not a simple washer as the OP originally believed.
Old Mar 16, 2026 | 08:26 PM
jigoe007's Avatar
jigoe007
I guess I used the wrong term. Those reinforcements are installed on the car. I need the part inside the red circle at the top right.
Old Mar 16, 2026 | 09:54 PM
Rowdy Rat's Avatar
Rowdy Rat
That part (138494) is an external tooth washer with a 7/16” diameter hole.
Regards,
Stan Falenski
Old Mar 16, 2026 | 10:32 PM
jigoe007's Avatar
jigoe007
Thanks y’all! It’s item 8 that I need. The print is lousy in the manual!
Old Mar 16, 2026 | 11:35 PM
MelWff's Avatar
MelWff
Deleted
To Reinforcement
