1972 Corvette Big Block
Old Apr 16, 2026 | 11:07 AM
LittleRed72's Avatar
LittleRed72
Cruising
Default 1972 Corvette Big Block
Can someone advise me which dual plane oval port intake manifold that would fit under a 1972 Big Block Corvette LT-1 hood?
Old Apr 16, 2026 | 01:02 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Posting the exact question in multiple forums is a no-no
https://www.corvetteforum.com/forums...clearance.html
Old Apr 18, 2026 | 05:29 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Why not build the engine you want to build. Then put a hood on it that will fit?
Anything else is a compromise.
Old Apr 18, 2026 | 11:19 AM
LittleRed72
Cruising
4-vettes how much cash can you contribute to that?
Old Apr 18, 2026 | 04:54 PM
69L88's Avatar
69L88
I was going to offer up you swap over to rectangular port heads but I have no cash to spare.
Old Apr 18, 2026 | 11:05 PM
4-vettes's Avatar
4-vettes
When I installed a high rise hood on my 77. Absolutely no one contributed to the cause. However, even though I am anything but wealthy. I found a way. And I have had no issues with high rise manifolds and high air filters ever since.
Old Apr 19, 2026 | 08:26 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I believe the stock aluminum LS6 intake is all you got for a real choice. I see the prices all over the place on ebay, $500 to $1500....make sure the numbers are correct for a corvette intake
Old Apr 19, 2026 | 10:16 AM
69L88's Avatar
69L88
The LS6 manifold is for rectangular port heads and the OP is looking for something that will work with oval ports.
Old Apr 19, 2026 | 02:23 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Simple answer.
There is not an aftermarket oval intake port that fits that hood with a BB.
Only the two GM ones, the 569 Holley R-port repop, or the 68-69 GM C3 Qjet dual plane.
Old Apr 20, 2026 | 08:42 AM
mapman's Avatar
mapman
Simple answer.
Only the two Mm ones, the 569 Holley R-port repop, or the 68-69 GM C3 Qjet dual plane.
LittleRed72
Point of reference - purchased a 69 GM aluminum Qjet manifold in good condition for my LS5, a few months ago, for a couple hundred dollars.
Mapman
Old Apr 21, 2026 | 05:32 AM
Rescue Rogers
He can put a square port on oval port heads...which is his only option without going to an L88 hood
To 1972 Corvette Big Block
