I have a 69 BB and am going to install a Tremec TKX WR. 1st gear is 3.27 and 5th is .72. I currently have a 3.08 rear end and was contemplating changing it to a 3.55 or maybe 3.70. Recommendations?
The 3:70 (or 3:73) is the most popular choice when installing a TK. Problem today is finding good replacement gears. A friend of mine recently told me he saw a NOS set of US Gear 3:73s at a swap meet and the seller was asking $1000 for them.
3.27 first gear with 3.08 is just about perfect. 3.70s will drive you crazy. I have found about 10-11:1 in first gear is just about ideal on the street. Your 3.27/3.08 gives you 10.07:1. You could probably go to a 3.36 but any deeper is just too much.
I have the .64 overdrive in mine and if I had to do it again I would go with a lower gear. I had the choice of .64 or .82 and the .82 would probably have been better. Your .72 with the 3.08 rear is about the same as my final ratio. It should be fine since my complaint is just with the drop from 4th to 5th, not with the overall ratio.
BTW I have a 3.55 rear.
Just do the math
1st x final for your first gear or launch ratio
Examples:
Muncie 2.52 WR and 3.36 gears = 8.46 used with the base SB and BB
Your 3.27 x 3.08 = 10.07 which is stout, no go to 3.70= 12.09 Very short.
When the TKO were the deal they came with 2.87 so 2.87 x 3.73= 10.70 and many liked that combo, OD dropped the cruise to about 2200-2400 with plenty of torque.
3.27 x 3.36 = 10.98 which is close to the TKO, you have to see what the OD drop is and make sure the engine won't be lugging in that range.
After 11 miserable hours, we got the TKX installed. What a PITA, but, side pipes knocked an hour off of install time since exhaust was a non issue. It is a nice upgrade. Still on the fence on changing the rear end. At 70 MPH, 5th gear drops RPM to 1800. At 60 MPH it drops it to 1500. I found a rebuilt 3.36 on GearPartsCenter for $217 and free shipping. Seems too good to be true. Has anyone dealt with this website? Is it legit? Other thoughts?
Is your big block mostly stock or have you made any performance upgrades to it.
I would leave your rear end gearing as it is and maybe look at a new camshaft that will produce more torque in the lower to mid rpm ranges.
You don’t want a high lift aggressive cam, because they can kill low end and mid range torque.
Find one that makes torque from off idle through 5000 rpm.
That way you’ll get more pulling power at 70 when cruising at 1800 rpm.
There are many hydraulic roller or hydraulic flat tappet cams that are easy to install.
There is no need to swap heads, intakes or carbs to install a better performing cam, but you can while you’re in there.
I have not done any mods, and don't know of any. From the block tag, it's 2003 ZZ454 from GM Performance. The car was an original 427 400HP tri power, and whoever swapped engines, kept the tri power on it. Those 3 Holleys are a PITA, but I dig them, in a nostalgic kinda way. This car is my childhood dream car. It's a big block, tri power, side pipe, 4 speed (well, now5 speed) coupe. The only box that isn't checked is that it's Monaco Orange, and my dream car is black. I'm really leaning towards leaving the rear end alone. For now, I plan on driving it this summer and deciding later. Cam does sound like a better option. This is my first big block car, so I'm still learning. I'm also recently retired, and have a very good friend who is been a car guy his whole life and is rapidly turning me into one. I'm learning fast, that once you go down the rabbit hole, there's no escape. I want to do the Borgeson steering upgrade and Wildwood brakes. And,and,and.......
