Fastener List
Old May 15, 2026 | 11:22 PM
Greezy's Avatar
Greezy
Default Fastener List
Does anyone have, or know where to find, a complete list of fasteners for the C3 (1980 for me)?
I found AMK here on some thread but their website is not doing well right now and I don't see Corvette Master Kits listed.
Old May 16, 2026 | 02:18 AM
hunt4cleanair's Avatar
hunt4cleanair
The NCRS Tech Manuals have an illustrated list of fasteners by Model Series (1978-79, 1980-82, etc.)
Hope this helps!
Old May 16, 2026 | 07:58 AM
Alan 71's Avatar
Alan 71
Hello G,
This is a fastener resource for 68-72 cars.
It will be of some help for your later car.
Regards....
Old May 16, 2026 | 09:24 AM
gbvette62's Avatar
gbvette62
While much of the original hardware is available from Corvette vendors, nobody makes complete Corvette body, chassis or engine hardware kits like AMK has for Camaro's, Chevelle's and Mustang's. About the only thing close to what AMK offers are the interior screw kits available for most year Corvettes. Since much of the hardware used on Corvettes was the same as used on other Chevrolet's, a lot of what you need for a Corvette can be found at AMK, if you know the size and headmark.
The Assembly Manual for 1980 will list part numbers for a lot of the fasteners used on your Corvette, though it's not easy to track down hardware with just a part number. Some hardware is included in original Corvette Parts Books if you have one, but most of the hardware was found in the GM Standard Parts Catalog. The Standard Parts Catalog is a great resource if you can find one, but it was designed for the dealer to be able to look up a bolt's or nut's part number by a description of the bolt or nut. It's not much help if you don't know what type or size bolt you're looking for.
hunt4cleanair is right about the NCRS 1980-1982 Corvette Technical Information Manual & Judging Guide giving you a description of many of the fasteners used on your Corvette. I was part of the team that worked on the 80-82 TIM&JG back in the early 90's. Surveys were sent out to owners of 80-82 Corvettes asking a number of things about their cars, including a description of a lot of the car's original hardware's head markings.
The now defunct Paragon Corvette used to do a fantastic wall chart showing most major Corvette fasteners, with photos of each head mark, the size(s) and application(s). These are invaluable if you can find one. Paragon's catalogs also had the fastener chart spread over a few pages in the back of the catalogs. One of their old catalogs might be easier to find than an old wall chart.
Old May 16, 2026 | 10:28 AM
pltmgr's Avatar
pltmgr
1953-1982 Corvette Parts and Illustration Manual. You can get one on eBay. Has all the fasteners sizes. You can get most a lot cheaper in a hardware store vs Corvette vendors.
Old May 16, 2026 | 01:59 PM
Greezy's Avatar
Greezy
Thank you for this invaluable info!
Old May 16, 2026 | 03:34 PM
Alan 71's Avatar
Alan 71
Hello,
It's true that hardware stores can be a ready source of fasteners.
These fasteners tend to be generic though and so may differ slightly from the original for various reasons
Whether or not this matters can only be answered by you.
Snotty people often refer to it as 'screen door hardware'.
So????
Regards...
Here's an example.....
Note the tapered shank. The part of the bolt that passes through the rubber busing is unthreaded to protect the bushing.
Note short threaded portion.
Note grading slashes and finish.
There is no adjustment in this bolt. The slotted nut can be torqued tight so the cotter pin can be installed. This insured consistent / constant ride heights for the rear suspension.
To Fastener List
By Michael S. Palmer | 2026-06-03 11:00:24
