Sloppy steering column
Old May 21, 2026 | 06:17 PM
jimgehret's Avatar
jimgehret
7th Gear
Default Sloppy steering column
I assume this needs a rebuild. It is a car that I just picked up. I linked a video below. Thanks for any incite!
Old May 21, 2026 | 06:27 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
The tilt knuckle bolts are loose. Common problem among GM tilts from 69-97. Your need some special tools to get to it
Old May 26, 2026 | 09:31 AM
69ttop502's Avatar
69ttop502
Jim, I agree with the above post that the 4 knuckle bolts are loose. Unfortunately, as NowhereMan said, you have to go deep into the column to fix. Not difficult but you need a couple of specialty tools to get in there. If you are anywhere near Long Island, I would be glad to fix it for you.
Bill
To Sloppy steering column
