1968 Wheel Width
Old May 28, 2026 | 07:32 PM
TXWillie's Avatar
TXWillie
Default 1968 Wheel Width
Pros/Cons converting to 8” vs 7” wheels? Going to keep stock trim rings and caps. Using 245/60r15 tires.
Old May 28, 2026 | 08:08 PM
Piersonpie's Avatar
Piersonpie
Not a big enough change to be worth the effort IMO. If you want a radically different change in handling I would go for 17”+ wheels with modern tire compounds.
Old May 28, 2026 | 08:33 PM
TXWillie's Avatar
TXWillie
Default 68 wheel width
Friend has 8 inch and wants 7”. Just trade. New tires coming the will work with either.
any negative or positive??
no cost.
Old May 28, 2026 | 08:37 PM
Piersonpie's Avatar
Piersonpie
It should fit without issue. I assume the tires you had on there before were thinner? No downsides
Old May 28, 2026 | 09:46 PM
Chagjr's Avatar
Chagjr
7” on the front 8” on the rear.
Old May 28, 2026 | 11:46 PM
69L88's Avatar
69L88
1968s were all delivered with 7” rims. 8” were introduced for 1969. If you want to retain originality, keep the 7”s.
Old May 29, 2026 | 08:54 AM
Alan 71's Avatar
Alan 71
Hello,
The original F70-15 tires used on early 68+ cars are equal to current 215-70 -15 tires.
So the same tire was used on both 7" and 8" wide wheels.
In looking at the appearance of various tires I find that the 'height' of the tire is important too.
Regards.....
Chagjr ....Nice looking 68!!!!
Old May 29, 2026 | 07:29 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
the 8 inch rim will let the front tires rub slightly on the frame at the rear of the wheel well at full lock...My tires just polished the frame. The rear wheels will be about an 1/8" or less from the emergency cable bracket. You may have enough room for the wheels, most people relocate that bracket as the factory did for the later years. You should just take the bare rim with some wheel weights still attach to see if they touch that bracket. 17 " rims arent a big deal and you can also solve the issue with some thin shims
THe 8 inch wheel is worth it as it spreads the tire out and gives it a wider tire patch given you use a wider than stock tire. I saw a video that had a small section on this subject but have no idea where I saw it. Only down side is finding a 15 inch tire that is high performance...the only really good tires easily available are the cooper cobras or the bfg radial t/a but the later has the letter browning issue. Both are only rated for sustained driveing just below 120 mph
Old May 30, 2026 | 07:32 AM
pltmgr's Avatar
pltmgr
My 68 had a 8 inch wheel and a 7 inch wheel on both the front and rear axles (???). I converted to all 8 inch rims and 255/60-15 tires. The fronts rub some on the frame but I like the overall look a lot better.
Old May 31, 2026 | 03:42 PM
mh_merc's Avatar
mh_merc
My opinion is that GM engineers decided to switch to 8" in 1969 for a reason. I run 245/60's front and 255/60's rear on my '69 L46; I've never had any rubbing or "frame polishing" issues with this setup and the handling is great.
Old May 31, 2026 | 07:15 PM
Rescue Rogers
The front spindles were changed in 69 that changed that issue and they went to a bigger bearing as the 68 ones would eventually seize to the spindle and throw the car violently to the left across 2 lanes of traffic at 80mph leaving a definite brown stain in your shorts....i have pictures of the bearing, .....not my shorts
To 1968 Wheel Width
