I have a 1985 350 Corvette engine.I'm trying to match up to a newly rebuilt 4l60e the problem I'm having is the crankshaft center is only 2 inches flange and the 6 bolt pattern are spaced 1 1/2 inch from center bolt to center bolt do they make a attachment where a regular 350 Chevrolet flex plate work thank you for any help Bobby
The engine sounds alright. The Automatic transmission not so much.
I agree, while it's apart, put in a manual, you'll be glad you did.
You can always sell that automatic to someone with a station wagon.
