Experience with Catco converters?
Old Jan 26, 2005 | 02:31 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default Experience with Catco converters?
I've decided to go to duals with cats on my '75 and looking for good, hi flow converters. Saw some universal fit converters at Summit, made by Catco with a SS case. Opinions?
Old Jan 26, 2005 | 05:06 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Brother has one on his 88, very nice CC. Much better than any stock ones.
David
Old Jan 26, 2005 | 10:25 AM
zwede's Avatar
zwede
I put one of those summit catco's on my spare car (old cadillac). I like it. Fit was perfect. Car passed emissions. Picked up power and added 2-3 mpg. Now the old cat was the ancient pancake type and plugged up by 20 years of crud so anything would have been an improvement, but the catco is definitely getting the job done at $75.
Old Jan 26, 2005 | 10:35 AM
Paul @ Thunder's Avatar
Paul @ Thunder
Several of the late model header systems use Catco cats and they work very well. On a 400rwhp car we will only pick up about 5-10hp by removing the cats. Only better cat that I know of woult be Random Technology but they are pricey. Hope this helps.
Old Jan 26, 2005 | 10:38 AM
Fevre's Avatar
Fevre
It does, I am thinking of putting a cat back on my 89 Formula just to be a little more enviro friendly.
Old Jan 26, 2005 | 10:44 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
My old, plugged cat needs replacing as well. I can't imagine that a new high flow cat would not be more effective than an old, clogged one.
Old Jan 26, 2005 | 11:52 AM
Wrecked82's Avatar
Wrecked82
I read somewhere once (really read it, not just heard about it) that a Catco flows better than the fabled Random Tech converter.
I have one and like it.
Old Jan 26, 2005 | 12:32 PM
LiveandLetDrive's Avatar
LiveandLetDrive
They're all the same once you gut 'em
That's my plan anyway, Ganey's exhaust thread had some dyno numbers showing big performance increases going from old cat to new highflow cat. I just can't stand the thought of losing even a little power if I can prevent it.
-Chris
Old Jan 26, 2005 | 12:41 PM
Tim Parker's Avatar
Tim Parker
My 81 exhaust is still factory stock. Big old pancake style cat Converter. Car only has 2k on it so it should not be clogged up too bad. Would I see a big difference with a high flow cat? Also would it be possible to put the factory one back on once or twice a year for NCRS judging ?
PureSilver's Avatar
PureSilver
will running these as dual cats make any difference on the 'environmental' end? e.g. too much catalytic for the flowrate? (obviously it will result in better performance!)
Old Jan 26, 2005 | 12:42 PM
Tim Parker's Avatar
Tim Parker
I should have written 20,000 miles not 2
Old Jan 26, 2005 | 01:41 PM
zwede's Avatar
zwede
Tim: Yes, it will make a big difference. Dyno testing from back around then showed the pancakes robbing 40-50 hp on a 250 hp engine. A modern hi-flow is more on the order of 5 hp on the same engine.
Old Jan 26, 2005 | 04:31 PM
Tim Parker's Avatar
Tim Parker
I had no ideal it was that much of a HP thief. Is the switch a nuts and bolts kinda thing?
Old Jan 26, 2005 | 04:40 PM
zwede's Avatar
zwede
Dunno. The car I switched it out on was not a Vette. Look through the catco listings on summits webpage and see if they have a direct replacement. For my Caddy they did have a direct replacement listed and it was just a matter of pulling the old one and bolting the new one in.
Old Jan 29, 2005 | 08:43 PM
Sarge81's Avatar
Sarge81
Hey Tim,
I'm new to the forum here. I have an '81 also. I had true duals custom bent with twin Catco converters. When I bought the car, it originally had the 2-1-2 system. No cat though, but instead a "test pipe" with the proper 4 bolt hole flanges. It's just sitting around collecting dust. If your interested in it, let me know.
If you are going to switch the cat. on and off, you'll need to "stockpile" some gaskets for the pipe flanges. lol.
Darryl
Old Jan 30, 2005 | 01:01 PM
bs82vette's Avatar
bs82vette
Default Test Pipe
I need the Test Pipe is Buffalo Dude does not want it.
Old Jan 30, 2005 | 03:40 PM
Buffalo Dude
St. Jude Donor '07
I'm going with duals as '75s no longer need inspection in the great state of California (but just to be environmentally conscious, I'll stick a couple cats in there. NO, NO, catalytic CONVERTERS, not felines
Old Jan 31, 2005 | 10:37 PM
Sarge81's Avatar
Sarge81
bs82vette,
If you want it. It's $35.00 total. S+H included. It's yours. Let me know.
If you want pics first, let me know. I'll take a couple and send them to you.
Darryl
Old Jan 31, 2005 | 10:40 PM
Edzred72's Avatar
Edzred72
I too used a pair of these when I built my 77. Illinois tests..so I had to have em. Very pleased...but I went directly through the manufacturer and saved some $$.
Eddie
To Experience with Catco converters?
