alignment:adjustable strut rod/offset shafts
Old Feb 3, 2005 | 11:06 AM
smoothsailing's Avatar
smoothsailing
Default alignment:adjustable strut rod/offset shafts
Just installed new trailing arm assembly on passenger side. Camber is way off. It was bad with the old unit, the bearings went, so put on a new unit and the problem is worse. Going to try adjustable strut rods. Anyone know of a unit that has the most range of adjustment? Also, looking for upper front contral a arms with offset shaft installed. Any ideas, can't seem to locate a compete unit. Most sell the shaft but not as a compete unit. PS the struts are near new on the car will be getting rid of them after installing adjustables, let me know if any one is interested.Thanks for any help.
Old Feb 3, 2005 | 01:01 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I don't understand how new t-arms will give you worse camber than your old units? Are your strut rods bent at all? Are the bushings good? Did you put the reducing washers on when you installed them? The reducing washers go on the bracket side under the diff. It doesn't make sence.
Why do you want offset a-arms shafts? Was the car hit or are you tring to get more camber out of the front? If you buy the HD upper a-arms they already come w/offset shafts and will give you more camber and caster. You said you couldn't find them as a complete unit. Do you mean the whole a-arm (stock) w/the offset shafts in them? I can build them for you. Here are the HD upper a-arms w/offset shafts.
http://www.vansteel.com/index.cfm?fu...&SubGroup=1851
Old Feb 3, 2005 | 02:40 PM
72-LT1's Avatar
72-LT1
I was told today when you install adjustable strut rods, you will need to have the strut rod support bracket welded to make it stronger.
Anyone here of this before?
Old Feb 3, 2005 | 02:58 PM
smoothsailing
Yea, I'm sure this sounded nuts. What happened is this, the car had a camber problem right rear and left front. The rear camber problem was not being able to bring the bottom of the tire in. Even with the camber adjustement bolt turned as far as it would go.I installed fixed original style struts so they are not bent. Had the car looked at a frame shop. They don't think the car was damaged in the front, they think it's normal age sag.They said my rear bearings were shot on the right side rear. So I replaced the entire trialing arm assmebly. Now the camber is worse. My performance shop is now playing with the suspension this afternoon trying to fix it. They are not sure why the camber would be worse with new assembly bearings etc. But it is. My thinking is to use adjustable strut rods to help with the problem. Drivers side front the spacers are removed from the upper control arm and still do not have proper camber. So I'm leaning towards offset shafts. The ones you have look great. Do you have those in stock? PS Thanks for your help.
Old Feb 3, 2005 | 07:42 PM
greg454's Avatar
greg454
It seems to me that if you have new trailing arm assemblies and good straight strud rods and still have you tire leaning in, then your side yokes on your differential must have excessive wear on them.
Old Feb 3, 2005 | 07:48 PM
70 LS1's Avatar
70 LS1
If you are having problems with camber on two opposite corners of the car, you probably have a bent frame. Take it to a different shop for a second opinion.
If you cannot get the alignment with stock strut rods you have some serious other problems. Throwing on adjustable strut rods and offset front shafts is not the correct answer. That is like treating the symptoms instead of the disease.
Old Feb 4, 2005 | 10:52 AM
zwede's Avatar
zwede
Yep. Easy to verify: Take the halfshaft off, grab the yoke (piece sticking out of the diff that the halfshaft bolts to) and pull it in and out. If it moves more than 50 thou or so it is bad.
To alignment:adjustable strut rod/offset shafts
