Progress on engine bay
Old Feb 6, 2005 | 07:05 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Progress on engine bay
Although the engine's show status the engine bay itself is lacking. I have everything off the firewall and fenders. Every part has been sandblasted, wirewheeled painted or clear glossed. That's the easy part. The firewall has stress cracks and an actual hole under where the hood release cable comes out in the left rear quarter panel. So it's alot of glassing and sanding, and reglassing,hardest part is achieving a baby smooth finish. I expect at minumum three weeks to do this as the motor is in the way of everything and I'm not looking forward to the taping off before spraying (think of the ceremic headers for example). Anywhere here's some progress,
this is the hole i was talking about. I saw a little bit of silver sticking up and when I pulled it i realized Bubba spray painted over duck tape covering a big hole.
Old Feb 6, 2005 | 08:59 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
IMHO, I would also swap out those red heater hoses to black.
Old Feb 6, 2005 | 10:46 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
go go go go... you do good work...i guess you got over being bored with it?
Old Feb 7, 2005 | 07:28 AM
EDDIEJ82's Avatar
EDDIEJ82
AH HA.... I see some dust on your car So..... your not superhuman after all
I'm sure after you get thru working on it it will look great as usual.
Folks, I have it on good athourity that Cali had all the dirt in Cal. removed and sent to Ga., That's why I can't keep it off mine
Old Feb 7, 2005 | 07:47 AM
kcmk's Avatar
kcmk
QUOTE]...wirewheeled painted or clear glossed...[/QUOTE]
Glossed?
I take it that you've decided to keep it, and not sell it? If so, then good for you!
Old Feb 7, 2005 | 09:17 AM
Cali,68,L-79
Exactly! The overflow and all the heater hoses are coming off tommorow. The PO used red ones for some reason.
To Progress on engine bay
