cam questions
Old Feb 8, 2005 | 11:56 AM
cmashark's Avatar
cmashark
Default cam questions
ok, this isn't really a corvette thread, but i can't work on my vette until i finish the wifes car. i have to replace the lifters and cam in my wifes camaro. do i have to do a cam break-in even though it has roller lifters?
chris
Old Feb 8, 2005 | 12:00 PM
mandm1200's Avatar
mandm1200
I know I should reply since I never owned a roller cam, but the break in should be minimal for a roller setup. Normally the lifters do not have to be changed on a roller setup unless there was a problem.
Old Feb 8, 2005 | 12:05 PM
cmashark's Avatar
cmashark
one of the lifters failed. it started to wear the lobe. i was hoping to not have to replace the cam....no joy.
Old Feb 8, 2005 | 12:13 PM
pws69's Avatar
pws69
chris
I definately would. You still have bearings and journals which need to "get to know each other" plus the roller to cam lobe contact is new.
Old Feb 8, 2005 | 12:16 PM
Fevre's Avatar
Fevre
IF the cam is OK you should be able to pop in the new lifter and not have to 'break it in' but I would be concerned that the old damaged lifter might have caused damage to the cam. Do you know what caused the lifter to fail?
Old Feb 8, 2005 | 12:18 PM
zwede's Avatar
zwede
There is no break-in with a roller cam.
Old Feb 8, 2005 | 12:21 PM
cmashark's Avatar
cmashark
i have no idea what caused it to fail. heck the car only has 66000 miles.
Old Feb 8, 2005 | 03:05 PM
redc3's Avatar
redc3
no break in with a roller cam/lifter setup. i do not however recommend synthetic oil during this initial startup.
To cam questions
