What the C3 REALLY needs
Old Feb 12, 2005 | 08:53 PM
  #81
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Originally Posted by Jeff 6T9
I should get some pics and post them by the middle of next week. Sorry I haven't gotten to it sooner.
Sounds great Jeff!!! I look forward to seeing them. Please post them in this thread so we can find them.
Dep
Old Feb 12, 2005 | 09:10 PM
  #82
platato's Avatar
platato
From: The Armpit of Illinois Platato says..... "Sometimes your the windshield & sometimes your the bug".
St. Jude Donor '05
Two words
Cup Holder
Platato
Old Feb 12, 2005 | 09:26 PM
  #83
SMH's Avatar
SMH
Two words
Cup Holder
Platato
I want a cup holder too.
Old Feb 12, 2005 | 10:01 PM
  #84
Stoge's Avatar
Stoge
Originally Posted by bobs77vet
and "french" no less.........
So was Louis Chevrolet...
Old Feb 12, 2005 | 10:16 PM
  #85
Glensgages's Avatar
Glensgages
Originally Posted by big632
I wouldnt trust someones back half job unless I saw it go down the track.
and even-then, I might
Old Feb 13, 2005 | 12:58 AM
  #86
SMH's Avatar
SMH
I agree. Thats why mine is getting professionally done.
Old Feb 13, 2005 | 01:32 AM
  #87
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I built up a Dana 60 IRS for my '67 and so far it's held up well to some mega rpm sidesteps with the 540 in front of it. It all bolts to stock mounts, uses stock trailing arms along with 3.5" halfshafts and 1480 series U-joints. Definitely not the easiest way to go, but hey...it's different! I did it in my driveway/garage. Took some work, but I pulled it off.
All that said, I have seen some guys in Super Stock racing with some creative solid axles under C-3's. They don't look "textbook" from a std design perspective, but watching them launch, proves they work. Probably the simplest one I saw, appeared to have taken the stock Vette trailing arms, cut off the part where axle stubs go through, and literally welded them solid to the 12 bolt housing. I would think a pivot point with an upper link would be better, but it seemed to work well with front tires dangling in the air on launch. Anyway, he appeared to have just limited the total travel similar to the way IRS guys do and had it going solid against snubbers on launch. He had made a new bracket for spring mount and still used the transverse leaf spring. If you didn't pay attention, you would think it still had an IRS in it. Since diff didn't move much, he probably didn't have to do too much for driveshaft clearance.
Take a trip to the next major event drag race and check out the Super Stockers. Might see some good ideas.
I'd like to see the pics too when they are available.
Thanks,
JIM
Old Feb 13, 2005 | 02:06 AM
  #88
2BAD's Avatar
2BAD
Dep, please check your PM.
I'm waiting to see those pictures.
Old Feb 13, 2005 | 07:49 AM
  #89
DJ Dep's Avatar
DJ Dep
2BAD: Great stuff in PM!!! I wonder if that place could do a kit like that for a Vette???!!!
Dep
Old Feb 13, 2005 | 10:03 AM
  #90
big632's Avatar
big632
Thanks,
JIM
I fabbed a system like the one you are talking about. The diff is we used coil overs instead of the transverse spring which was designed to be used with an irs. On a solid axle it has no reason to be there.It wont work nearly as well as coil overs with a solid axle. On super stockers they may still have to use it?So yes you could make a bolt on kit with welded control arms to the housing and a bolt on coil bracket system. You would need to drill a few holes but it would be a simple process and everything you removed could be put back.The only drawback is a very stiff suspension to keep pinion angle correct.Who wants one and how much are they willing to pay?
Old Feb 13, 2005 | 10:10 AM
  #91
DJ Dep's Avatar
DJ Dep
I'll take stiff suspension over mushy one any day
I want a solid rear axle, but it has to be a Ford unit. Coils, leafs, or transverse...I don't really care. A long as everything lines up and stays rock solid, that's all I worry about.
Dep
Old Feb 13, 2005 | 10:12 AM
  #92
panchop's Avatar
panchop
but... don't you still end up with a rearend that was enginered for way less HP then it will be asked to handle?
Old Feb 13, 2005 | 10:37 AM
  #93
big632's Avatar
big632
Why. you got a solid axle set-up with whatever carrier and axle spline you want.I would go 33 or 35 spline with a 9inch and your good to go for all but the most demanding powerplants and then you still wouldnt have enuff tire to hurt it.Its still going to cost some money two to three thousand im thinking.
Old Feb 13, 2005 | 10:45 AM
  #94
panchop's Avatar
panchop
any chance you have a picture. i guess i'm just not clear on it.
Old Feb 13, 2005 | 11:07 AM
  #95
big632's Avatar
big632
No. Just imagine a solid axle rear attatched to the control arms instead of an IRS.Now you have the strength of the solid axle vs the irs.Personally if your not going to tub it and dont need bigger tires I would get the stronger toms irs. Still breakable but doubtful with any tire your going to get under there.
Old Feb 13, 2005 | 11:45 AM
  #96
EDDIEJ82's Avatar
EDDIEJ82
This is what I was talking about earlier in the post. Except I would use a ladder bar setup to attatch instead of a cut trailing arm and coilovers instead of the transverse rear spring. If the ladder bars were double adjustable it would be a lot easier set the pinion angle
Mike how will the driveshaft clear the rear crossmemeber , with rearend travel? does it get in the way? I talking about the one on the frame at the pinion mount not the one attached at the upper part of the older diff's
Old Feb 13, 2005 | 01:17 PM
  #97
big632's Avatar
big632
That one would be removed . Travel would be limited by stops.I would need to see a pic to refreshen my memory,its been a while.any factory set-up to look at ,then I could get into more detail.
To What the C3 REALLY needs
Old Feb 13, 2005 | 01:59 PM
  #98
EDDIEJ82's Avatar
EDDIEJ82
Ok here's one I pulled out of the member gallery, the cross member in front of the pinion that is the back part of the frame is what I'm talking about. With the IRS the diff is fixed but with a solid axle it wouldn't be. See what I mean?
Ok I can't cut and paste it and my pic server is down
Old Feb 13, 2005 | 02:25 PM
  #99
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Originally Posted by DJ Dep
I don't know where people are finding Novas with big blocks that are worth a dang for $6000, but in my area they are well over $18,000. That's MORE than I paid for my Vette.
Dep
Hmm...that's good to hear. I thought I was going to have $15k tied up in a $6k car.
Old Feb 13, 2005 | 08:18 PM
  #100
redc3's Avatar
redc3
i posted this same info very early in this thread. i think it would be pretty simple. i bet you could even use stock ta location as a bolt on point for your ladder bar, and use coil overs. easy.
