Water Pump recomendations
Old Feb 13, 2005 | 04:30 PM
Retro78's Avatar
Retro78
Default Water Pump recomendations
I need to replace the pump on my moderatly enhanced 355. The cooling system is new without any cooling issues but the pump is starting to leak(OEM style only 2 years old). This time I would like to go with a better quality. Those aluminum polished ones sure look nice. Any recomnendations would be appreciated. I see lots on ebay but not sure of the quality or if I need a long or short shaft.
Old Feb 13, 2005 | 04:39 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
I went with an Edelbrock and have no complaints.
Old Feb 13, 2005 | 04:46 PM
Older Than Dirt's Avatar
Older Than Dirt
If you are still using your stock pulleys, brackets you need a short pump. I'm using a edelbrock, works just fine. You also need to replace it with one specifically for corvettes.
Old Feb 13, 2005 | 06:23 PM
ZD75blue's Avatar
ZD75blue
Have any of you guys used an aluminum pump?
Old Feb 13, 2005 | 06:34 PM
Older Than Dirt
Edelbrock pumps are aluminum. Stewart makes aluminum pumps for vettes also.
Old Feb 13, 2005 | 08:00 PM
John 65's Avatar
John 65
I wasted my money on one of those "Flow Kooler" pumps years ago.I think thats what they are called, with a disk on the impeller to enhance flow and reduce temps but it didnt change or improve a thing. Sounds like edlebrock is the way to go.
Old Feb 13, 2005 | 08:32 PM
Hitch's Avatar
Hitch
Stewart Components Stage II water pump...
Old Feb 13, 2005 | 08:48 PM
page62's Avatar
page62
Ummm...brand new ACDelco unit???
Old Feb 13, 2005 | 09:12 PM
bertmeister's Avatar
bertmeister
Stewart Stage 1 installed last year. No problems.
Old Feb 13, 2005 | 09:36 PM
panchop's Avatar
panchop
i have a nice edelbrock victor, bolted right up the my 327 in my 65 and worked fine. needed a little grinding on the altermator support arm to fit right but it took about 5 minutes.
greg
Old Feb 13, 2005 | 10:02 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Feb 14, 2005 | 10:05 AM
SteveG75's Avatar
SteveG75
GM Performnace Parts aluminum. Nice piece.
Old Feb 14, 2005 | 10:23 AM
68/70Vette's Avatar
68/70Vette
Last week someone showed a GM Performance Parts aluminum water pump for a Corvette (a short pump.) It was only $99. Seemed like a good buy.
Old Feb 14, 2005 | 10:47 AM
SteveG75's Avatar
SteveG75
That was me. It was $99 at Scoggins Dickey. www.sdpc2000.com
Old Feb 14, 2005 | 12:39 PM
Retro78's Avatar
Retro78
Thanks for all the feedback guys. I off to the store.
Old Feb 15, 2005 | 01:27 AM
gearheadz's Avatar
gearheadz
THE best!!!
Old Feb 15, 2005 | 01:32 AM
i885744's Avatar
i885744
I've got a brass works, but only kuz they're local.
To Water Pump recomendations
