Need help--AR Racing engine problem
Old Feb 15, 2005 | 02:20 AM
BigBlockk's Avatar
BigBlockk
Didn't someone here on the forum have an adapter that bolts to the bell housing bolts and wraps around the block to provide a pivot. I seem to remember seeing a picture of something like that.
BigBlockk
Later.....
Old Feb 15, 2005 | 04:02 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
BigBlockk
Later.....
This is Viet Nam Vette's 502 with the bolt-on clutch rod bracket. Slick clutch rod setup he has too.
Old Feb 15, 2005 | 11:38 AM
Homie's Avatar
Homie
OK, GS, I sent them again. Lemme know if you get them tonight.
Is that adapter Viet Nam Vette used an aftermarket piece that I could get or did he build it himself?
That thing does look pretty sweet.
Old Feb 15, 2005 | 12:40 PM
stingr69's Avatar
stingr69
An adapter like that can be bought from Scoggin Dickey Chevrolet.
-Mark.
Old Feb 15, 2005 | 12:47 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I'll check for the e-mail when I get home...
Old Feb 15, 2005 | 02:00 PM
Homie's Avatar
Homie
stinger,
I am pretty ignorant. Would that completely prevent the need for me to have someone machine the block? I have a McCleod clutch and a 6-speed ROD tranny.
Thanks.
Old Feb 15, 2005 | 02:18 PM
BigBlockk's Avatar
BigBlockk
http://www.sdpc2000.com/catalog/1006...l-Brackets.htm
Yes here it is. Thanks Jughead and Stingr69, Ya'll come through again. Yes this should make machining of the block unnecessary.
BigBlockk
Later.....
Old Feb 15, 2005 | 05:46 PM
GrandSportC3
here are the pics!
Old Feb 15, 2005 | 07:52 PM
Homie's Avatar
Homie
OK, somebody help me with those pics.
He is trying to indicate where the missing machining is. Is he in the right spot? Should I just buy the attachment to avoid the machining? Maybe that is easier, and I guess I avoid the risk of the machine guy ruining the block (how big a risk is this)?
Thanks to GS and everyone else for help.
Old Feb 15, 2005 | 07:56 PM
GrandSportC3
Don't think that it's a big risk to drill it.. You won't need to have to drill too deep and the block should be pretty thick there..
Old Feb 15, 2005 | 10:48 PM
84rzv500r's Avatar
84rzv500r
A few months ago I ordered a 400 CI crate engine from AR Racing.
So the engine builder finally got around to putting it in. Just awhile ago I talked to him and he said that on the side of the block where bosses are they are not tapped and drilled for a clutch linkage. He said this is wierd as they should come from the factory drilled as such.
He sent me some pictures, but I don't even know what I'm looking at. Can I email them to anybody tonight that can post them for me?
I called AR Racing, but no answer, so I'll try back. They KNEW that I was going with a stick-shift because I got a part number from them for the flywheel they balanced against. It was crystal clear.
What should I tell them when I call them? The engine builder said he didn't even know if a local machinist would do the job because of liability concerns (drilling into the water passages and ruining the engine). AR Racing should pay for it to be shipped to them so they can fix the problem, right?
THanks for any help/suggestions.
zz502 and ramjet 502 BBC have same problem... scoggins-dicky have a bracket for 50-60 bucks to solve this with no drilling and tapping...
Old Feb 16, 2005 | 12:38 PM
Homie's Avatar
Homie
bump from any other responses.
Any reason the bracket might possibly NOT work with my clutch/block combination (Mclead clutch, 400 block)?
I think I am going to tell him we can just order the bracket and forget about the machining. That is unless there is any reason the bracket might not work.
Thanks again.
Old Feb 16, 2005 | 12:46 PM
  #33
LFZ's Avatar
LFZ
I want that clutch rod setup..where do you get that????
Old Feb 20, 2005 | 05:05 PM
  #34
84rzv500r's Avatar
84rzv500r
looks like the one i have from speed direct...
