Need help--AR Racing engine problem
Old Feb 14, 2005 | 11:59 AM
Homie's Avatar
Homie
Default Need help--AR Racing engine problem
A few months ago I ordered a 400 CI crate engine from AR Racing.
So the engine builder finally got around to putting it in. Just awhile ago I talked to him and he said that on the side of the block where bosses are they are not tapped and drilled for a clutch linkage. He said this is wierd as they should come from the factory drilled as such.
He sent me some pictures, but I don't even know what I'm looking at. Can I email them to anybody tonight that can post them for me?
I called AR Racing, but no answer, so I'll try back. They KNEW that I was going with a stick-shift because I got a part number from them for the flywheel they balanced against. It was crystal clear.
What should I tell them when I call them? The engine builder said he didn't even know if a local machinist would do the job because of liability concerns (drilling into the water passages and ruining the engine). AR Racing should pay for it to be shipped to them so they can fix the problem, right?
THanks for any help/suggestions.
Old Feb 14, 2005 | 12:05 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Just try calling them at different times of the day.. You'll get somebody on the phone for sure.. I've been on the phone many times with them and most of the time I was able to get somebody on the phone... They are a small business and they are somebody busy or at their other shop...
I'm sure Mark will be able to clear up things with you...
I've never even heared about blocks that aren't drilled for manual transmission
The only hole that you need is where the Z-bar attaches.. I have a 400 small block from them and the hole is there...
Never heared about different blocks for MT or AT cars
Old Feb 14, 2005 | 12:07 PM
Homie's Avatar
Homie
GrandSport---can I send you the pictures and you take a look and tell me what you think (and maybe post them if you can)? I have no idea what I am looking at.
Old Feb 14, 2005 | 12:08 PM
GrandSportC3
I'm at work and can't post pictures from work. You could e-mail me the pictures to my home e-mail address and I could host them and post them when I get home..
grandsportc3@tampabay.rr.com
Old Feb 14, 2005 | 12:12 PM
LFZ's Avatar
LFZ
some 400 blocks didn't come with the hole tapped for a clutch bar..if i'm not mistaken, you can drill and tap it yourself.
Old Feb 14, 2005 | 12:18 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
They have 2 bosses, one near the oil filter and one further towards the center of the block you want this one not the one near the oil filter, any machinist can drill and tap this easily
Old Feb 14, 2005 | 12:19 PM
Homie's Avatar
Homie
Great, I'll send them your way shortly. If you have time, please take a look at them and see what you think.
Old Feb 14, 2005 | 12:49 PM
GrandSportC3
I'll check them out when I'l get back home at about 5 PM... I can also host and post them for you.
I agree with the response that if the hole isn't there, a machine shop should easily be able to drill and tap that hole... Shouldn't be more than $20 - $50...
Old Feb 14, 2005 | 12:50 PM
Homie's Avatar
Homie
Grand, sent them your way. Thanks alot.
Old Feb 14, 2005 | 12:51 PM
page62's Avatar
page62
Call some local machine shops yourself to see if they could do the job (if you don't want to do it yourself).
Don't count on what your engine builder says -- you know the old saying, "Trust, but verify."
Old Feb 14, 2005 | 12:56 PM
lars's Avatar
lars
We drilled and tapped our own clutch linkage ball hole on the 406 AR we received. 400 blocks from auto trans vehicles don't have the hole drilled or tapped - this is normal. Just drill and tap it yourself - no big deal.
Old Feb 14, 2005 | 12:59 PM
munday's Avatar
munday
We just got one of the AR eng. at the shop and it was also not drilled!! The block was a 350.
Old Feb 14, 2005 | 01:52 PM
DropTopBigBlock's Avatar
DropTopBigBlock
AR Racing have a website? I did an MSN search and couldn't find anything.
Old Feb 14, 2005 | 01:55 PM
Homie's Avatar
Homie
They sell only on Ebay as far as I know.
Go to ebay, then find your way to the complete engines section. Click on some chevy engines and you will find them quick. They seem to sell more 383 strokers than anything.
to the top for grand helping me out tonight.
Old Feb 14, 2005 | 02:23 PM
stingr69's Avatar
stingr69
Not all blocks have all the bosses drilled and tapped for clutch linkage. Different chassis require different clutch linkage locations. Some vehicles use a boss on the bellhousing so the block would not even need to be tapped at all. You gotta know all the intimate details and very few people have all the info.
This isn't much help I know.
-Mark.
Old Feb 14, 2005 | 06:16 PM
Homie's Avatar
Homie
bump for GS to post the pics!
Old Feb 14, 2005 | 10:06 PM
GrandSportC3
Didn't receive the e-mail..
Could you re-send??
To Need help--AR Racing engine problem
Old Feb 14, 2005 | 10:07 PM
GrandSportC3
http://www.maxhorsepower.com
Their website hasn't been updated in ages.. Still got the old e-mail on there...
Old Feb 15, 2005 | 12:57 AM
oregonsharkman's Avatar
oregonsharkman
Weird wild wacky stuff!!! My AR 383 was drilled.....doesn't look like a big deal to do it yourself tho.....
Old Feb 15, 2005 | 01:02 AM
glen242's Avatar
glen242
Check the size that is drilled and tapped on the boss. I made sure that I was sent a block with the proper 'Z' bar location tapped. It was, but, it was tapped for 7/16" not the 1/2" NC 13 that was on my original block. Quick fix with the proper size drill and tap took care of it. BTW, the rear hole (bellhousing) was tapped for the 1/2" NC 13.
