Piston Ring Question
Old Feb 15, 2005 | 03:56 PM
Gage's Avatar
Gage
Default Piston Ring Question
The 30 over flat tops that came with my unassembled big block have new piston rings on them. I am going to bore to 60 over and have purchased some 60 over Speed pro dome pistons. Assuming the groove sizes are the same, can I use the rings from the 30 over pistons on the new 60 over pistons.
Old Feb 15, 2005 | 03:59 PM
BB wowbagger's Avatar
BB wowbagger
Unless youre going to use a rhinoshot of n20 i would say no
Old Feb 15, 2005 | 04:55 PM
marshrat99's Avatar
marshrat99
No way unless the rings you have are actually uncut then you might have a chance.
Old Feb 15, 2005 | 05:33 PM
LemansBlue68's Avatar
LemansBlue68
Maybe. If the rings are file to fit. I'd say no if they are pregapped. Also consider if the rings you have are 1/16 thick rather than 5/64. Production rings are 5/64. If they are 1/16 as in some Hipo applications then, no way.
To Piston Ring Question
