Engine Hoist, Harbor Freight?
Old Feb 15, 2005 | 04:18 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Engine Hoist, Harbor Freight?
Hey all, I'm going to buy an engine hoist soon as I have a few things I want to change before I screw everything back together. So has anyone bought one of these from Harbor Freight and are you happy with it? Is there someplace else I should consider? I assume the 1 ton will be enough for my sbc? TIA
Old Feb 15, 2005 | 04:26 PM
isosceles's Avatar
isosceles
I bought mine from Northern. I'll try to find the url when i get home. Its a 2 ton folding with free balancer that was on sale for $199. We have Northern and HF stores here in town.
Old Feb 15, 2005 | 05:30 PM
Bob Turner's Avatar
Bob Turner
YES- I bought that two ton unit. Very happy with it. very durable.
Go for it. I think I paid $170 for it a couple years ago....
Bob
Old Feb 15, 2005 | 05:41 PM
mandm1200's Avatar
mandm1200
I have one but haven't got to use it. With these engine jack, are they long enough to pull the engine from the front? Most cars would not be a problem but the C3 has the engine sitting back further from the front bumper
Old Feb 15, 2005 | 05:51 PM
gkull's Avatar
gkull
Mine is the 2 ton and I never pull the hood. just one less thing to put back together.
When i had my headers recoated. sitting on the 2 ton hoist.
Old Feb 15, 2005 | 07:34 PM
ckerch's Avatar
ckerch
I bought a 2 ton unit from Harbor Freight last fall for 170. It pulled my big block and transmission together .
Worked great !!
Old Feb 15, 2005 | 07:35 PM
steves_77vette's Avatar
steves_77vette
Got mine from HF. Good unit. I went with the regular model vs the foldable. The regular one has a longer boom arm to get in to the motor since the nose of a vet comes out so stinkin far. You need enough distance at the 1 ton set point of the boom to get to the center of the motor when you pull it.
Old Feb 15, 2005 | 07:51 PM
shamby's Avatar
shamby
Got one and love it. I even used it to lift the body off the car. I purchased mine about 5 years ago and use it constantly.
Old Feb 15, 2005 | 08:00 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Bought mine at Homier when they were in town for $129 and it works great!! Had engine with attached tranny tangling for 2 days without an issue...
Old Feb 15, 2005 | 08:18 PM
Gary79's Avatar
Gary79
unless you are going to use one all the time, why not rent one? I had this option, but a friend let me borrow one for free. i didn't plan on pulling engine/trannys very often so i didn't buy one. definitely get the longest boom you can find.
Old Feb 15, 2005 | 08:44 PM
SmokedTires
St. Jude Donor '05
Gary, when I borrowed one last spring I didn't think I'd be pulling the motor again already so borrowing was fine. I realize this is one of those tools I won't use often, but I hate asking to borrow things and I like having things available if I need it. With my luck, borrowed things sometimes break and I end up buying one anyhow but for someone else .
It looks like Harbor Freight may soon get my purchase since they have a store nearby.
Steves 77, that's a great point. I will certainly check into the lengths between the foldable and non so I can get the longer of the 2.
Thanks everyone
PS. Is this a general or a technical section question
Old Feb 15, 2005 | 09:11 PM
markdtn's Avatar
markdtn
HF is probably OK. I got mine at Sams.
Old Feb 15, 2005 | 09:21 PM
1974slcvette's Avatar
1974slcvette
Default Engine Hoist / Engine Stand Combo
Checker has an 2-ton folding engine crane / engine stand combo, for $149.00. Made by Champion. I haven't had a chance to see it in person yet...
Old Feb 16, 2005 | 02:40 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Can't speak for your area but here in NJ the local Pep Boys has had one advertised for months in their weekly sunday flyer for $109 plus a $10 rebate. It can't be the best for that price, but certainly worth checking out if your intent is to only use it a couple times.
I rented one a couple years back and paid 2/3 of this price for a rental. If I needed one again, I'd certainly check out the $100 special first.
FWIW. Good Luck!
Old Feb 16, 2005 | 07:16 AM
vetteonr's Avatar
vetteonr
If Harbor Frieght's engine lift is anything like their scissor lift, it should be a good item. I like my scissor lift so far.
Old Feb 16, 2005 | 08:24 AM
SmokedTires
St. Jude Donor '05
We on't have checkers, but we have an Autozone & Pepboys locally that I'll also check out. Otherwise it'll be HF
Old Feb 16, 2005 | 08:38 AM
kens 80's Avatar
kens 80
I have seen the Harbor freight ones and would go with the 2 ton and the have a sale where they throw in the engine titler with the 2 ton so it actually costs about the same as the 1 ton plus the tilter. I have a non foldable 2 ton unit unk brand I bought used for $50. works great. When I got it I though, gee I can always borrow one, but since I have it I have used it many times and not always to pull an engine. Did you ever try to pick up a chevy eng and trans that you son knocked off the dolly?
Old Feb 16, 2005 | 11:31 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
mine is from pep boys and was either 109 or 119 last november...
Old Feb 16, 2005 | 01:04 PM
71roadster's Avatar
71roadster
I got one at harbor frieght also. I did not get the 'collapsable' model because it still takes up a lot of floor space. The 'non-collapsable' model comes apart with 3 bolts and stores tightly against a wall.
The pumps are known to blow seals with little use - but I skipped the extended warranty. If the pump blows, I would rather go pay for a better pump than replace it with the same piece of junk.
Chris
To Engine Hoist, Harbor Freight?
