oil pressure
Old Feb 26, 2005 | 03:42 PM
C3Muscle352's Avatar
C3Muscle352
Default oil pressure
my oil pressure guage always reads at either 0 or 100 [obviously broken] and i was thinking i would just replace the switch and see if it would fix it. my question is, is there more to this than i can see or are the only two things that can break are the switch and the guage?
Old Feb 26, 2005 | 06:32 PM
BerniesVette's Avatar
BerniesVette
I'm assuming it is electric. It could be a wire shorting out too. Sending units are cheap so it wouldn't hurt to start there. Good luck.
Bernie
Old Feb 26, 2005 | 10:21 PM
SLine78's Avatar
SLine78
The oil guage in my 78 was acting the same way. Got a replacement sending unit from NAPA, installed it and now have a working guage.
Old Feb 26, 2005 | 11:12 PM
yogi78's Avatar
yogi78
I think you can test the gauge by just grounding the wire from the sending unit. When grounded the guage should read full. Thats how the temp guages work and I think the oil pressure guage works on the same principal.
To oil pressure
