Rockers... Again
Old Feb 26, 2005 | 07:02 PM
superdad60's Avatar
superdad60
Default Rockers... Again
Okay here is a close up
Are these nuts with the allen locks after market?
I hear talk of pressed in rocker bolts, but these look threaded.
I have had 4 rockers whose jam nuts were still tight and holding in place but the space (lash) in between rocker and valve, you could slide in a dime. It was a bit noisy.
Today on the way home after running 3000 rpms for 15 minutes on interstate... a hell of a racket happened inside right valve cover. Shut her down and opened it up to see one rocker with a quarter inch of play. Made adjustment and got home, Much quieter now of course.
Questions:
1. Shop Manual says after tightening just firm make another 3/4 turn on the bolt. Is this correct? I thought there should be a feeler gauge space between.
2. Is there a way to check or tell about a cam problem without pulling cam out?
3. Also what is the little clock on the head? Time or month built?
Old Feb 26, 2005 | 07:05 PM
Gordonm's Avatar
Gordonm
Those are definitly aftermarket nuts. Is the cam a Hyd. or a solid cam. Solid should have some clearance. Hyd will not have clearance. The 3/4 turn depends on the cam and manufacter.
Old Feb 26, 2005 | 07:09 PM
superdad60's Avatar
superdad60
Not sure...Have never been inside the motor that far. After running the pushrods feel spongy so I would say hydraulic. So no space is what I should have eh?
Old Feb 26, 2005 | 07:11 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
I am sure others will chime in. But in my humble opinion I would take those off and go to a Chevy Dealer and purchase stock nuts to put on instead. With those type of nuts you usually have to have the studs machined to a flat surface for the nuts to retain tension correctly.
Also no feeler gauge as it seems you have a hydraulic cam so it is normal that when you adjust the lifters of which I like to do running you bring them down just till the noise stops and then go 1/2 to 3/4 turn more. As mentioned before depending on cam.
As for the clock I have no idea unless it moves lol.
Old Feb 26, 2005 | 07:13 PM
superdad60's Avatar
superdad60
Tick Tick Tick
Old Feb 26, 2005 | 07:50 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
you think your screw in rocker studs are backing out.
did you check to see if they are tight and bottomed out in the head?
Old Feb 26, 2005 | 07:55 PM
Ironcross's Avatar
Ironcross
This is really your best choice
Old Feb 27, 2005 | 01:42 PM
superdad60's Avatar
superdad60
How do the stock nuts retain their hold?
Do they have a crimp on them or something?
Old Feb 27, 2005 | 02:01 PM
Jclgodale3's Avatar
Jclgodale3
I've had this same problem recently on a fresh motor. I believe the stock nuts are a type of "lock nut". Once they have been taken off and on a couple times, the "lock affect" seems to go away. Some have said they can only be used a couple times. I will be purchasing new nuts myself. Others have said you can take a punch and hammer to the top of the nut (which I believe makes the nut edge irregular) and it should start locking in place again.
Old Feb 27, 2005 | 03:08 PM
Fevre's Avatar
Fevre
You can pull one of the nuts off and see if the stud head is flat. You really need to find out if that is a hyd or solid cam in order to adj it correctly. I assumed I had a hyd cam and after I had a piston blow I found out it was a solid cam, I was try to use the hyd lift adj tech so I might have been the cause of the piston exploding. When I adj the lash for a hyd cam using the locking nuts I tighten the nut about 3/8 turn once the chatter stops, tighten the set screw nice and snug then turn the nut another 1/8 turn, this really gets them tight, I had been just tightening the set screw and have had a few come loose but none since I used this method.
If it turns out you have a solid cam you might be able to use the same method but you will have to make sure you tighten the nut and recheck the lash with a feeler gauge.
Those locking nuts are a step up from the stock nut so I am not sure why you would want to put stock type nuts on there.
To Rockers... Again
