In many (if not all) books that I have read before replacing my brake lines it said that it is impossible to replace the long line without lifting the body.
Brake lines CAN be replaced with the body on in one piece - did the one on my 69 with S/S - just be careful and take your time.
Fuel line, however, is another story........
??? Isn't that what I said ?
" In many (if not all) books that I have read before replacing my brake lines it said that it is impossible to replace the long line without lifting the body.
My lines were leaking so I had no choice but to replace them.... I left the body on, I removed the long line without cutting it.... I thought "if I can get it out without cutting or excessive bending, then I can get the new one in without lifting the body"
This turned out to be true - no problems whatsoever getting the new stainless line in there.... well, it's tight but it can be done...
Don't let the books scare you, sometimes (fortunately) they are wrong !!! "
