snap bolt removal
Old Mar 1, 2005 | 07:07 PM
JDRez42's Avatar
JDRez42
Default snap bolt removal
I broke both of my trans mount bolts off in the trans case. I allready have them drilled and trying the extractor along with soaking PB blaster. Trying to be careful so i don't break the extractor. Any other ideas to try?
Old Mar 1, 2005 | 07:18 PM
Maco78's Avatar
Maco78
last time that happened to me. Like exactly that cept was a mount for my fog pump on the intake manifold i just drilled out the exact same size hole. slowly moving up in drill bit sizes, and then i rethread it. But thats just me, and its because i was impatient.
Old Mar 1, 2005 | 07:21 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
have ya tried to GENTLY & LIGHTLY heat the case around where the bolt holes are? A lot of times when you heat it, it will expand the metal and break loose the corrosion around them and you can then back them out.
Old Mar 1, 2005 | 07:39 PM
NHvette's Avatar
NHvette
Yeah - heat will help most (or cold on the broken bolt).
Old Mar 1, 2005 | 08:00 PM
wattac2's Avatar
wattac2
First make sure the drill hole is centered as good as possible. Then use left-hand drill bits, those that drill by rotating opposite to the normal direction. Start with a small size then move on up. The heating of the drilling and the twist of the drill will "back the broken bolt out". If the bolt can be taken out this way is the best.
Old Mar 1, 2005 | 08:11 PM
john1977's Avatar
john1977
Ok wattac2 tell this old guy where you get left turn bits,never knew there was such a thing. Think i need to add some to my tool set.
Old Mar 1, 2005 | 08:48 PM
LemansBlue68's Avatar
LemansBlue68
Definitely some heat will help! Especially with an aluminum case. I've heard of guys heating the area and then quenching the bolt with a shot of penetrating oil. This causes the bolt to contract away from the case because of the cooling and the oil to soak between the case and the bolts. Both good things.
Old Mar 1, 2005 | 08:59 PM
David Ey's Avatar
David Ey
carefull , if you heat the aluminum too much you will take all the hardness out and it will be dead soft and not hold a bolt well.
Old Mar 1, 2005 | 09:51 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
My grandfather had a bunch of them. They were ground differently than normal bits. I asked the metals tech and structures guys I work with about them and you would have thought I was talking Greek to them!
Old Mar 1, 2005 | 10:07 PM
hiyosilver's Avatar
hiyosilver
Heres a trick you can try .Heat the area around the bolt .Before it cools take a candle and melt in area .When heated and expanded wax will ooze bewtween threads .
Old Mar 1, 2005 | 10:20 PM
A78Corvette's Avatar
A78Corvette
Left handed drill bits, and kriol penetraiting oil might work.
Old Mar 1, 2005 | 10:34 PM
canucbuck's Avatar
canucbuck
If all the suggestions that have been posted fails the one thing left to do is to take out the unit and have the bolts edmed out. This is a electro discharge machine that uses a copper electrode slightly smaller than the bolt. The electrode thru electrical current burns the bolt away and you then pull the remainder of the threads away with a pair of needle nose pliers. Most machine and tool and die shops would have one.
Old Mar 2, 2005 | 12:32 AM
FEDX's Avatar
FEDX
From: A high school diploma fixing what a college degree broke TN
Look locally for a machinist supply place,if not I think Graingers,McMaster Carr or one of the other big places would have them.We have some at work,and while it helps I have not gotten good enough results with LH drill bits to warrant going to any trouble for them.Using Kroil as a penetrant or the good quality extractors like Snap-On sells is way more important to me.By the way,the actual company that makes the extractors for Snap-On is sold on ebay under their own name for about twenty bucks a set.A guy at work showed me the ones he got and they are the same,can't remember the name but they are in a red plastic case with about 8 extractors in it.
Old Mar 2, 2005 | 08:07 PM
JDRez42's Avatar
JDRez42
Well it happend. I was heating and quenching with penetrating oil and the extractor snapped in the hole. This sucks. I have to go to the shop tommorow to pick up my block so i will see what they can do.
Old Mar 2, 2005 | 10:49 PM
wattac2's Avatar
wattac2
Now that the hardened extractor is in the hole move on to a drimel cutter bit, a small one with a "ball" style head. I've had good luck grinding out the extractor and the bolt. If you're real careful most of the bolt will come out before you start cutting into the threads. I've also cut through one side of a bolt, completely through the threads, after grinding out most of the bolt, then use a small sharp chisel to "unwrap" the remaining parts of the bolt out of the hole. You'll probably have to clean up the threads with a tap. Takes time.
Good luck, been there, done that, several times.
And, as some of the previous posts indicate, left hand drills are available at most better machine supply houses. And if you get them keep them separate from all your other bits. Its real fustrating trying to drill with them when you have the drill rotating in the normal direction. Lots a heat and smoke, but litte action. Like I said, been there, done that.
To snap bolt removal
