LS1 Conversions HERE!
Old Mar 2, 2005 | 04:50 PM
70 LS1's Avatar
70 LS1
I am going to go against the other LS1 swappers out there and say GO FOR IT. Sounds like a cool project.
I am using a driver's side vette manifold and a passenger's side F-body manifold for now. I have a set of long tube headers I am modifying to fit. Oh yeah, and cutouts.
Old Mar 2, 2005 | 05:08 PM
BeaterShark's Avatar
BeaterShark
Originally Posted by Budman78
Your lucky, I've never had a carb'ed car that would start on the first try after a month of none use. It was always pump, pump, turn, pump, turn, cuss...
Well, I cheat in that I have an elect fuel pump and I don't let it sit more than 3 days, unless un-drivable in some way.
As for the manifolds, does the engine sit in the same location as a Gen I? If so, couldn't you cut a LS1 exhaust flange and weld it to some Gen I headers?
Old Mar 2, 2005 | 05:29 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
That's what I am doing right now. There is a guy on ebay that is selling LS1 flanges for $18 and I'm going to weld them to a set of BB headers. Should work, so we will see. F-body headers are big bucks.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WD1V
Old Mar 2, 2005 | 08:06 PM
lostpatrolman's Avatar
lostpatrolman
budman, are those the same flanges GM sells, or are these thicker? The nice thing about FI is the flexability of the system. Some guys are running unthinkably large cams and their cars are still streetable.
Old Mar 2, 2005 | 08:40 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
GM sells the flanges????? Send linky.
Old Mar 2, 2005 | 09:12 PM
lostpatrolman
I donno, I thought I saw them somewhere. I could be wrong though...
Old Mar 2, 2005 | 09:39 PM
Ex_F-Body_Enthusiast's Avatar
Originally Posted by holley505
WELL just to clear the AIR a little bit...
The engine is stock 2000 model....
The heads are from truck and have been worked....
I am getting the motor as a long block... no intake no wiring harness no computer....with f-body accesories.
This is a swap project that never happened...because of cash....I get to benefit (I am getting the motor checked )
The reason for the CARB... a it will be cheaper than the fuel injection ( I am paying for this job to be done..SORRY GUYS DON'T HAVE THE TIME TO DO THIS ONE....or the patience)
1) it will be different
2) have you seen the lastest craze with muscle cars and LS1 motors?
3) it will KICK THE CRAP out of a GEN I motor
4) the car came from the factory with a carb?
5) I have a carb already
6) less wires and no computer in a already cramped car? MY car doesn't have a gove box... BUT A MAP HOLDER....
Yeah it would be cool to have fuel injection... but this will make my car unique and those who don't have a CLUE will be shocked!
what do you think?
and manifolds.... corvette ones work??? yes or no?
no shorty headers here...manifolds will do. I have no cats and mid america chambered exhaust...
Are you still planning to run the 4L60E? Last time I checked, it requires a computer to control the shifts.
Old Mar 2, 2005 | 09:44 PM
Scooter70's Avatar
Scooter70
Yup, they do make 'em. I've seen the part # posted on LS1Tech before.
Old Mar 2, 2005 | 09:47 PM
lostpatrolman
4l60E is computer controlled
Old Mar 2, 2005 | 09:48 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
cool add the FI and a 700r4....good luck
Old Mar 2, 2005 | 09:54 PM
lostpatrolman
I searched ls1tech and found them...
Gm pn 12480130
http://www.gmpartsdirect.com/
Old Mar 2, 2005 | 10:32 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Gm pn 12480130
$14.49 cheaper, cool.
Old Mar 2, 2005 | 10:46 PM
  #33
Mike Mercury's Avatar
Mike Mercury
By carbing it, you are getting rid of a major advantage of doing the swap in the first place.
I gotta agree with that. The main advantages with the LS1 are the light weight. and then the FI.
Since I have both a C5 and L82 C3 (actually the C3 is the wifes car) the main difference I can detect is the magnificant throttle response at low RPM WOT... and partial throttle response the LS1 FI gives.
The PCM FI setup on the LS1 always gets you the proper fuel mixture during any... and all partial acceleration scenarios - during all air temp, water temp, and weather conditions.
And then going WOT ... you don't get so bogged down at the beginning when the RPMs haven't climbed above 3500 yet.
I have an Innovate WB AFR setup and the LS1 fuel management system is truly amazing. Of all the previous systems placed on (pre C5) Vettes, I think the General finally got one right.
Old Mar 3, 2005 | 12:06 AM
  #34
holley505's Avatar
holley505
Well as far as trannies.... a got a viper spec T56 with a stage III spec clutch and all the fixens.... but I have it sold ( i believe) I am sticking with the TH350 for now...ARGHHH stop the flaming
I will be running a 2400 stall...looks like I may upgrade to a 2800-3000 with the cam...
I am trying to keep it simple and inexpensive...
MANIFOLDS..... Looks like or sounds like any of the factory ones will work... I prefer ZO6 02-04 manifolds if I can get them... they flow the best out of all the other factory ones... I saw that in the recent hotrod magazine...
As far a out running GEN I motors... I think (know) I will have edge on them for the mods I will have...IF YOU DON'T know this yet... you will learn it from one of the many heads and cam GEN III motors out there.
I am willing to bet that I will out dyno any factory ZZ4 or fast burn engine....which is basically a heads and cam GEN I
Old Mar 3, 2005 | 12:42 AM
  #35
lostpatrolman
Im pretty sure the z06 manifolds are the exact same as the normal c5 ones.
Old Mar 3, 2005 | 12:54 AM
  #36
holley505's Avatar
holley505
not according to hotrod mag?? dunno though
pics of the motor
Old Mar 3, 2005 | 01:14 AM
  #37
Mike Mercury
they are, starting with model year 2001. Pre 2001 LS1 C5 exhaust manifolds were different.
To LS1 Conversions HERE!
Old Mar 3, 2005 | 03:12 AM
  #38
djcwardog's Avatar
djcwardog
what do you think?
I'm with you, I think it is very cool! I like the idea of putting in the modern mill but running a carb on top. That manifold apparently comes with a kit to trigger the spark. The other stuff would have to be figured out anyway even with FI. You'll probably save money. I also think you can tune the carb to run very nice. Most of us are running carbs now on our old motors and we aren't all rushing out to convert them over to aftermarket FI. Of course, an integrated FI system on the LS1 (or even on the stock motor...) would start up easier and likely deliver better power at part-throttle. But at WOT I'll bet you can get the carbed motor to really sing! Go for it and let us know what problem areas may come up. I may do this one day with an old C3 that has no motor...
Old Mar 3, 2005 | 06:08 AM
  #39
Fevre's Avatar
Fevre
Yes you should be better than a those stock eng's but there are plenty of people running non-stock Gen I's.
Sounds like a intersting project, make sure to post lots of pics.
Old Mar 3, 2005 | 07:35 AM
  #40
SteveG75's Avatar
SteveG75
$0.02
With that cam, forget the Edelbrock setup. GM has a single plane carb manifold for the LS1 and MSD will be selling the ignition setup separately. MSD builds the Edelbrock version but their own will be much more tuneable (may be via laptop).
For the manifold go to www.sdpc2000.com, LS1/6 parts
Ignition www.msdignitions.com New products
If you can find a copy of the Winter 2004 Engine Masters magazine (Popular Hot Rodding pub), there is a good article in there.
I was thinking a carbed LS with my Tremec but I like the sidepipes too much (and no $$$) so I am sticking with the Gen I for now.
