LS1 Conversions HERE!
Old Mar 4, 2005 | 05:11 PM
  #61
Scooter70's Avatar
Scooter70
Originally Posted by holley505
cool ... so I could stick with the factory F-body pulley and may just have to trim the brackets here and there? Are All you guys usings the factory alt or the LS1 alt? no issues with the power steering pump?
And there is a factory water neck out there that GM makes that will work!
Thanks for all your help guys!!!
You need to use the LS1 alternator. It plugs right into the harness. If you're keeping power steering, you'll probably want to do the exact same setup that Budman has. Jeff and I have no PS so we could move the alternator without worrying about the pump.
Old Mar 4, 2005 | 06:23 PM
  #62
70 LS1's Avatar
70 LS1
yup, what he said.
Old Mar 4, 2005 | 06:25 PM
  #63
70 LS1's Avatar
70 LS1
So the easist way to go with manifolds... is the corvette ones? The f-body ones? or a mix of corvette and f-body??
I wasn't able to get the passenger's side vette manifold to work because it hit the idler arm. I already had on the driver's side vette manifold so I just left it and run one of each.
Old Mar 4, 2005 | 07:13 PM
  #64
holley505's Avatar
holley505
BUDMAN!!
How did you setup your pulley system? are you using a/c? if so the factory compressor or the LS1 compressor?
Old Mar 4, 2005 | 09:56 PM
  #65
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
BUDMAN!!
Sent you a email.
