Vacuum question ?
Old Mar 2, 2005 | 03:19 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Default Vacuum question ?
I just purchased a vacuum gauge, and did a quick check on the manifold vacuum, My concern is at idle, form what i've been reading it is normal that the vacuum level is slightly lower because of my agressive cam, but is it normal that the needle jumps (flickers) one or two points when idling. when I give it gas, it steadies out.. This vacuum thing is all new to me, but doe's not seem very complicated, its these little things that only experience can answer. I'v checked the old posts, and even checked a hot rod forum (oups ),, but nothing to help me..
Old Mar 2, 2005 | 03:23 PM
gerry72's Avatar
gerry72
If it's a slow fluctuation, it's probably some instability in the carb. Idle mixture adjustment, leaking boosters, bad gaskets...
If it bounces, then that's a bigger issue as it would likely be in the valve train.
Old Mar 2, 2005 | 03:27 PM
viperjesse's Avatar
viperjesse
Vacuum leak somewhere???
Old Mar 2, 2005 | 03:48 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
all those flickers mean something....did yours come with a sheet of paper that relates what the needle is doing to a list of problem areas?
Old Mar 2, 2005 | 03:54 PM
NHvette's Avatar
NHvette
If you are running a high duration cam, and the idle is slow and
lumpy, then you are likely seeing the pressure pulses as each
cylinder draws mixture in. This coupled with some valve overlap
will show the intake vaccum being reduced with overlap to the
exhaust. This would be more pronounced at idle, when the pulses
have time to propagate back to the vacuum port. At higher RPM,
the dynamics of mixture flowing through the manifold will smooth
out any variation.
I'd say you are OK, unless there are other symptoms.
Old Mar 2, 2005 | 04:00 PM
Fevre's Avatar
Fevre
If the timing of the fluctuations are assemetrical you might have a problem but if it is a pretty steady flicker then it is prolly the PCV valve working.
Old Mar 2, 2005 | 04:02 PM
LOTAHP's Avatar
LOTAHP
Hi hear KIRBY is a real good make.
Old Mar 2, 2005 | 04:13 PM
kevinator80's Avatar
kevinator80
out any variation.
I hope you are correct as my car shows the same type readings on a gauge. I had blamed it on the cam and 1.6 ratio rockers. I just wont hook it back to a gauge. Outa sight outa mind.
Old Mar 2, 2005 | 04:23 PM
Michel B's Avatar
Michel B
The motor is quite new, I mean it was rebuilt last year and I only put about 3ooo miles on it, it was a total overhaul, so I would be very surprise if it were bigger problems, but then, all is possible. The gauge did come with a paper for trouble shooting, and it is pointing out to valve timing or ignition timing, it also refers to a possible leak or bad compression, I dout the later. The flicker is very constant and minor in my oppinion,,. Is there a way to pinpoint a leak on the manifold ? I recall reading something way back but can't find it.
Old Mar 2, 2005 | 04:26 PM
Garys 68's Avatar
Garys 68
Yes the symptoms can be valve train, ie sticking valves, etc. But my 68 small block has a BIG cam, headers, sidepipes, aftermarket intake, and a very lumpy 600rpm idle and I see the same fast flickeing. Everything checks out OK.
Gary
Old Mar 2, 2005 | 06:02 PM
lars's Avatar
lars
Sounds completely normal. A car with a bit of a cam will bounce the needle around. I've had cams aggressive enough that the needle bounces so bad you really can't get a vacuum reading unless a restrictor oriface is placed in the gauge line to smooth out the pulses. If you have a lumpy idle, you will have a bouncing needle at idle. You don't have any problem.
Old Mar 2, 2005 | 06:21 PM
Michel B's Avatar
Michel B
Old Mar 2, 2005 | 11:03 PM
bobs77vet's Avatar
bobs77vet
heres those diagnostic instructions:
http://img.photobucket.com/albums/v4...s/00000847.jpg
http://img.photobucket.com/albums/v4...s/00000846.jpg
Old Mar 3, 2005 | 09:22 AM
75 Hot One's Avatar
75 Hot One
I wouldn't be concerned unless there's another problem such as bogging or hesitatation, etc. I've got a Comp Cams 292H in a 350 running at 6.5" vac at idle. Needle bounces at least 0.5" but smooths out at higher rpm and engine pulls smoothly & quickly from idle. The pulsations are likely due to pressure pulses from the valve overlap. This may suggest that the idle rpm is a bit on the low side. If it concerns you, try increasing idle rpm a bit. Pulsations should decrease or disappear.
Old Mar 3, 2005 | 11:35 AM
Michel B's Avatar
Michel B
Sounds like mine, I realy don't have other symptoms, the engine runs rreal nice and pulls hard. I want to play around with the carb calibration, do a little experimenting, got a calibration kit from edelbrock. Hope to widen my knowledge and maybe improve the performance. This is why it is important to be sure that all these little things are correct..... thanks all !!!!
Old Mar 3, 2005 | 11:58 AM
bobs77vet's Avatar
bobs77vet
in all of my years of restorations i consider the vacuum gauge one of the best diagnostic tools...if you learn to use it and read it properly you will become a very good engine tuner....good luck
To Vacuum question ?
