Connecting rod question
Old Mar 3, 2005 | 06:02 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
Default Connecting rod question
Since I'm in the middle of an engine rebuild (dropped off at the machine shop today!), I'm still trying to decide what kind of rods I should use. Car is being set up as street/autocross, 355 with 280 duration cam and keeping the revs below 6000 rpm. Is it worth the investment for brushed scat 4130 rods, or am I just throwing my money away? Durability is the idea here. So what do you all think?
trw
Old Mar 3, 2005 | 06:41 PM
Gordonm's Avatar
Gordonm
Probably not but it is insurance against breakage. I run the Chevy "Pink" rods which are fairly good for a stock rod and take mine to 6500 to 7000 rpm quite frequently. It has about 6K miles on the motor and never misses a beat. So far so good.
Old Mar 3, 2005 | 07:10 PM
Glensgages's Avatar
Glensgages
I agree with Gordonm:
not-necessary, but nice insurance if you can afford them.
I, too, have the 'pink' rods in my 355", and when I began racing it, I took to 6200-6400 regularly, but I shortly realized it went just as fast shifting at5800.
Old Mar 3, 2005 | 09:19 PM
Entropy's Avatar
Entropy
Is there a modern day equivalent to the "pink" rods? Would a scat 4130 brushed rod similar, or does it have to be a specific forged rod? Does H-beam or I-beam make a difference?
thanks for answering my questions. Everytime i do a google search, all i seem to get is where to buy, not the info I need. I appreciate the posts from those who have "been there, done that".
trw
Old Mar 3, 2005 | 11:19 PM
kens 80's Avatar
kens 80
In the early 70's ( yes I'm now 59) I had a 68 Chevelle that I built a 355 for. It had 12.5 comp, steel crank GM slant plug 202 heads and blue printed "pink rods", along with a lot of other goodies. Car was a 4 spd with a chevy 12 bolt with 5.13 gears it ran a best of 12.22 at 121 mph in the 1/4 . Went thru the lights at 9300 rpm never a problem with the lower end. All this with a GM Power solid flat tappet cam, Edelbrock Scorpion manifold and a Holley 850. The answer was attention to details and carefull assembly of "blueprinted" parts.
P.S. the car was stock bodied and was street registered(gas ,
Sunoco 260 and 34 cents a gallon)
PPS Moral to story, PINK RODS.
Old Mar 4, 2005 | 08:40 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Pink or PM rods will be fine, if you can afford it the Scat rods are probably a little stronger
Old Mar 4, 2005 | 11:49 AM
Entropy's Avatar
Entropy
here is some info I found on the "pink" rods.
Man, they built things tough back then.
302 (Z/28>
* small journal, 11/32 rod bolts in 1967
* large journal, 3/8 rod bolts 1968, 1969
* forged steel
* shot peened
* heat treated
* magnafluxed (known as "pink rods" due to the pink residue)
* babbit dipped
* 1967 - early 1968 pressed pin
* late 1968 - 1969 floating pin
No wonder they're such a hot commodity. thanks for the info everyone.
trw
Old Mar 4, 2005 | 12:11 PM
Fevre's Avatar
Fevre
According to GM the powdered metal rods are even stronger.
Old Mar 4, 2005 | 12:28 PM
gkull's Avatar
gkull
I ran some bushed 6.125 oliver lightweight 585 grams 4340 forged I beams.
They could feasably be the last rods you would ever need. You can reuse them in all future projects. I imagine mine are still out there probably still running around some circle track somewhere.
I keep reusing my 6 inch bushed Manley H beams.
If your going to do something - Do it right and then you don't even have to think about it down the road when you decide to turn the wick up to 7500 rpm or install a blower or N2O.
Same thing with good forged cranks and pistons. I just keep using them over and over. It doesn't cost anymore to do 6 inch over 5.7 rods so why short yourself.
Old Mar 4, 2005 | 01:18 PM
kens 80's Avatar
kens 80
302 (Z/28>
* forged steel
* shot peened
* heat treated
* babbit dipped
trw
They actually had a dab of pink paint on them from factory.
Old Mar 4, 2005 | 02:20 PM
gkull's Avatar
gkull
In all fairness to GM rods. I need to state that my 1979 L-82 vette bottom end (Forged Crank and rods) never failed me.
One of the first things I did was yank the motor to get the compression up. The motor was nearly brand new and I put on some forged flat tops on the stock rods. New cam and head work and headers with true duals. It was allso balanced. 6000 rpm every day. Then I got better heads and 64 cc chambers, bigger cam, and single plane intake. That stock 4 bolt bottom end saw 7000+ rpm for every day till it got about 100,000 miles on it.
Those rods & crank withstood abuse of every kind in a low 400 hp 355 ci motor with several variations and sizes of pistons attached.
The L-82 engine plant was worth ever extra penny.
Old Mar 4, 2005 | 02:44 PM
GTR1999's Avatar
GTR1999
What are the limits of a stock L-48 rod?
Gary
Old Mar 4, 2005 | 03:12 PM
bracketshark's Avatar
bracketshark
I've never seen a broken chevy x-rod, I've seen them bend but never a broken one. I would use new ARP rod bolts resize the big end and wouldn't think twice spinning them to 7000 Rpm. I ran a set in my automatic drag car for 3 years, 355 ci, 7000 to 7400 rpm shift every pass. The steel chevy crank broke coming out of the water box. The rods were unusable (bent) but never failed. Just My .02 worth
Old Mar 4, 2005 | 04:03 PM
carbster09's Avatar
carbster09
Default Scat rods?
Aren't the scat rods made in China now? I know the cranks are. At the very least they might be forged in China and finished here. That's made in China in my book and it will not be used on my vette!
I like the pink rods, ditto on length!
carbster
Old Mar 4, 2005 | 06:13 PM
stingr69's Avatar
stingr69
Sounds like a plan Fine for pressed pins but if you need bushed floating rods you should just get some Eagle SIR's. The cost from an Eagle dealer is about the same by the time you are done. Eagle is a better piece for floaters.
-Mark.
To Connecting rod question
