Heads
Old Mar 10, 2005 | 02:55 PM
MrSharky's Avatar
MrSharky
Default Heads
Did the L82 heads flow any better than the L48 heads on the 1980 Corvette or were both the same?
Old Mar 10, 2005 | 03:16 PM
SG4206's Avatar
SG4206
The L-82s had 2.02 & 1.6 valves. L-48s had 1.94& 1.5 ; so valve size alone let the L-82s breath better. I think the castings flowed about the same with equal valves.
Old Mar 10, 2005 | 04:40 PM
Nate '69's Avatar
Nate '69
Old Mar 10, 2005 | 05:38 PM
Boofers's Avatar
Boofers
According to this site
http://www.stingray.nu/tips/tech80.htm
both engines had the same head casting number of 462624.
This site here
http://www.chevytalk.com/tech/engine/SBC_Heads.html
has this to say about this casting number.
"624" – 462624, 426624, or 458624. The 458624 was a truck head, with 1.72/1.50 valves – non performance. The other castings were used mid 70's and up on 350 engines, they came with 1.94/1.50" or 2.02/1.60" valves, had 76CC combustion chambers, DO have accessory holes, intake port volume is 161CC's, exhaust port volume is 62CC's. These heads are made of thinner castings and are prone to cracking.
Old Mar 10, 2005 | 06:30 PM
page62's Avatar
page62
The L82 will flow better due to the bigger valves. But they are large chamber 76cc smog heads. If you can afford to, a head swap WILL give you the desired bang for your buck.
Old Mar 10, 2005 | 06:36 PM
MrSharky's Avatar
MrSharky
Default Thanks
You guys are great, thanks.
To Heads
