Power steering does not return after a turn
Old Mar 11, 2005 | 09:51 PM
bob2169's Avatar
bob2169
Default Power steering does not return after a turn
Alright, this forum has help me a great deal and I am still dreaming about the day I can take my vette out for a joy ride. One question before I order a new steering gear box. My steering does not return or return very little to the straight position after a turn. From what I ve read, the steering box can be adjusted but all the explanation I ve read appear to be in greek for me. I am thinking replacing a 25 years old steering gear box maybe easier to comprehence.
Can someone assist some explanation about the different od adjustments of the PS gear box (in plain English). Thanks
Bob
Old Mar 11, 2005 | 10:27 PM
BARRY L-48's Avatar
BARRY L-48
Default power steering
I recently had a similar problem with my steering and all I did to solve it was to loosen the lock nut on the gear box and turn the center screw(common screwdriver) alittle at a time until you get it were it feels right.Also, is your steering cylinder properly adjusted this will also cause this problem,and of course check for proper fluid in the power steering pump.If you turn the adjusting screw to far you can put to much play into the steering and you will have excessive play
Old Mar 11, 2005 | 10:33 PM
bob2169's Avatar
bob2169
Thanks for the quick response, which way should I turn the center srew on the gear box? There are proper fluid in the PS pump. As for the cylinder, I just replaced the control valve and balanced the cylinder in accordance to the instructions that come with the control valve. I am planning to check the cylinder balanace again. Thanks
Old Mar 11, 2005 | 10:43 PM
BARRY L-48's Avatar
BARRY L-48
I would definitley recheck the control valve balance,and when I had to adjust my gearbox, I turned it slightly clock wise but I really think you have control valve not balanced correctly, I thought my gearbox would need to be replaced as the car is a 1980 but I am glad that I didn't spend the money cause it didn't need to be replaced.I also had excessive play in the steering and that adjustment took care of that as well.I am sure that someone out there might have some other thoughts about it.Had another thought,after you balanced the control valve di you bleed the system by jacking the front of the car and turn the whheels to the left and right?
Old Mar 11, 2005 | 10:54 PM
FeedVaal's Avatar
FeedVaal
You should do a front end alignment with max caster and slight toe-in before considering other steering adjustments.
Old Mar 11, 2005 | 11:49 PM
bob2169's Avatar
bob2169
When I changed the CV, I balanced it and also bleed the system as you described. I will recheck the CV balance b4 adjusting the gear box. Thanks.
Old Mar 12, 2005 | 02:50 AM
rihwoods's Avatar
rihwoods
Did not see anyone say how to check CV balance.We put the monster up on jacks,and in neutral,started the engine with the steering wheel centered,and if it moved right or left on it's own,the balance needed to be adjusted. Right ? Just saying this as I learned the hard way after blowing hoses upon putting a new CV without doing this.
Old Mar 12, 2005 | 07:35 AM
Matt Gruber's Avatar
Matt Gruber
dont overlook the obvious!
Old Mar 12, 2005 | 10:14 AM
LemansBlue68's Avatar
LemansBlue68
It's really important to make sure the front wheels are off the ground when adjusting the balance on the control valve. Otherwise, the additional pressure can stir up air trapped in the system and turn the PS fluid to a froth making it difficult to purge the air properly. You might try balancing the CV again after the car has set for a while and any air has separated out of the PS fluid. Also make sure that the alignment is good and none of the suspension components are sloppy. The gear box is the last thing I would consider replacing (but I wouldn't rule it out).
Old Mar 12, 2005 | 10:16 AM
kevinator80's Avatar
kevinator80
Did you have this symptom before the control cylinder change (obvious)? I so, maybe check alignment or else where. If not Chilton's repair manual has info on centering the valve.
Old Mar 12, 2005 | 12:19 PM
GTR1999's Avatar
GTR1999
Check the alignment and balance first,if you don't correctly adjust the box you'll wreck it. I have 2 boxes here now that just like that and new gears run up to $240! If you need help let me know I might have a rebuilt box here ready to go next week. I'm trying to clear out the boxes I have.
Gary
To Power steering does not return after a turn
