How much Pumping is too much Pumping?
Old Mar 13, 2005 | 04:20 PM
OneBrokenSmile07's Avatar
OneBrokenSmile07
Default How much Pumping is too much Pumping?
First off I'd like to say that my dad finally agreed to let me drive my car again!
But now to the problem. I always pump it once in the morning or whenever I initially start it. It gurgles a little but pretty much starts up pretty nice.
Now when I shut it off, no matter how much of a period of time it is off, i always have to pump it again. even if I shut the car off to get gas, If i don't pump it after the 5 minutes of it sitting it'll start up very sloppily and idle lower then it should and etc.
I just put a brand new carb and intake on it so I don't know why it does this. Is it normal to have to pump it nonstop?
(Ps when I do pump it nonstop it gives that "flooded carb start", you know the kind of start you get when your carb is partially flooded, it kind of chugs and then roars, its hard to explain.)
Old Mar 13, 2005 | 07:08 PM
marshrat99's Avatar
marshrat99
Usually on a cold start like over night, I pump three times. If the engine has been sitting for a couple or three hours, I pump once.
Old Mar 13, 2005 | 07:42 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
sounds like the float isn't set right.....how well does it start hot when you hold the pedal down half way...
Old Mar 13, 2005 | 11:28 PM
OneBrokenSmile07
I'm afraid to do such a thing with a nearly new carb, I don't want to break anything.
I guess that's my cautious side shining through, but should I try it?
To How much Pumping is too much Pumping?
