I am at the point where I 've removed 3 hex screws (inside) and one nut (engine compartment) and the Heater core housing will not budge. What else has to be done to get it out???????
It is a 1970 with A/C
Have you removed the evaporator box in the engine compartment??
I just changed the heater core on my 73 and had to remove everything from the firewall in the engine compartment first, then remove all the ducting under the dash that attaches to the heater box. Only then was I able to lift the box up and off of the firewall from the inside.
Please do not use the crow bar anymore, when I first got my vette every single box, and duct under the dash was broken because one of the previous Bubba's that worked on it had tried to remove them with a crow bar. But if you do break things at least be nice and leave all the peices under the carpet so the next guy can glass everything back together like I did on mine.
The heater core for a car with A/C comes out from the inside of the car. There is no reason to remove anything other than a single nut and the hoses from the engine side of the heater box.
Jay
You were right about removing the hoses! Actually the hose clamps were stoping the housing from coming out, they just would not fit through that conduit .
These clamps were REAL tough to get off the hoses because they were hidden behind the A/C box.
Found out car had the original heater core still in it a Harrison
70 B.....my build date is June 25
What would be the best sealent to use. Something that will remain plyable.
Where are you going to use the sealant? After all of the work to remove the core I would not try to putty up the leak but rather my recommendation would be to have your heater core recored by a radiator shop. The original Harrison cores fit better then any of the current replacement ones - even the ones from GM. If you decide to go with a replacement core let me know and maybe we can agree on a price for your old Harrison one.
When I installed my core there was no sealant between the heater box and core and I am not sure you would want any in there. If you are talking about sealing the heater box when you reassemble it, I used a thin bead of RTV silicone since no one will ever see it and the silicone is not likely to dry out and stop sealing.
I have no idea about the cost to recore your heater core but I would suspect it to be in the area of $40-50.
Everything in this thread is true as I know it, but I was able to replace the heater core in my 69 non air unit from the front. In looking at the heater core from the firewall side, there is a tab held by two small hex head screws on the left side of the core. This tab has two **** which grab a retainer and keeps it from coming out the front. Take a look with a small mirror for a better view. If you remove the two screws or push the core forward and pull up on the retainer the core will come out the front. I am a little vague on the pushing or pulling, but definately worked for me. When I did mine this way it was all original and not "bubba." I ultimately ended up disassembling everything anyway to rebuild the box, but noted the tab for future reference. If you only need to replace the core, take a look with a mirror for the tab, it could save you a lot of work.
An air car is a totally different animal that an non-air car. There is NO way that a heater core in an air car can be removed from the engine side without using a sawzall. It is totally encased within the interior heater box and the hole in the firewall is not big enough to get the part through. It's even worse if we are talking about a BB car. In a BB car there is just enough room to get your hand between the exhaust manifold and outside heater/evaporator box.
