Throttle return spring question
Old Mar 19, 2005 | 08:17 PM
Ryan77's Avatar
Ryan77
Default Throttle return spring question
I installed and adjusted the carb linkage on my new 383 with a Speed Demon 750 today. My question is do I need to install a throttle return spring? The linkage and throttle blades return to the "off" (closed) postion as soon as I let go of the throttle, even from WOT. But, will it do this once I have the motor running? I didn't know if maybe the Speed Demon had a built in throttle return. Or am I missing something here? Someone please enlighten me
Thanks in advance
Old Mar 19, 2005 | 08:23 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
yes absolutely....and it should be a double spring (one inside the other) i had to mount my spring so it was up by the 2nd intake bolt from the front.
[IMG][/IMG]
Old Mar 19, 2005 | 08:25 PM
lars's Avatar
lars
Yes. Absolutely. You need a throttle return spring. The spring on the throttle shaft is not designed or intended to provide safe and consistent throttle return - Barry Grant even makes a point of this in their otherwise pretty poor installation instructions.
Retro78's Avatar
Retro78
Yes! and you actually need two. Do not rely on the spring built into the carb. You need two return springs, they are wound differently and typical one is placed inside the other. This is a saftey feature. Since the springs are wound different they break at different stress points and age.
Old Mar 19, 2005 | 08:27 PM
lars's Avatar
lars
Hey Bob -
That's pretty funny... we both said exactly the same thing at the same time without seeing each other's posts before they went up...
Old Mar 19, 2005 | 08:33 PM
bobs77vet's Avatar
bobs77vet
Originally Posted by lars
Hey Bob -
Lars, every once and a while a blind squirrel finds a nut...my goal is to have all of my answers be like yours.
[IMG][/IMG]
Old Mar 19, 2005 | 08:35 PM
Ryan77's Avatar
Ryan77
Thanks for the replies. I already have the bracket and dual springs, so I'll install them tommorow. Just wanted to be sure that they were neccessary.
Lars- I also setup the carb according to your paper, it was very helpful
Old Mar 19, 2005 | 08:41 PM
Ryan77's Avatar
Ryan77
I noticed that Bob's spring looks much more durable than what I have.
I have something like this: http://www.jegs.com/cgi-bin/ncommerc...29&prmenbr=361 .
Do you guys think that would be sufficient? Maybe something like this might be better? http://www.jegs.com/cgi-bin/ncommerc...63&prmenbr=361
Old Mar 19, 2005 | 09:03 PM
bobs77vet's Avatar
bobs77vet
i bought the 1st spring one you listed and tossed it ....the one i have on there is now is recycled from the previous carb..
Old Mar 19, 2005 | 09:09 PM
jdmick's Avatar
jdmick
I got stainless ones at NAPA. They seem plenty strong.
Old Mar 19, 2005 | 09:13 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Mar 20, 2005 | 01:11 PM
Ryan77's Avatar
Ryan77
I think I will order the second one I listed and toss the one I have. It just looks much stronger and more reliable
Old Mar 20, 2005 | 05:13 PM
joe73vette's Avatar
joe73vette
The first one is the same as the factory spring. Joe
Old Mar 20, 2005 | 05:16 PM
w1ctc's Avatar
w1ctc
Nothing gets your attention more than the throttle going wide open when your not expecting it. The car suddenly seems to have 600 HP and while your thinking about stomping on the clutch or turning off the ign. the world is going by at light speed.
Don't mess with bubba throttle returns.
Old Mar 20, 2005 | 06:12 PM
bobs77vet's Avatar
bobs77vet
if its like the one i got, it looked similar but the quality was way lower....
To Throttle return spring question
