About ready for a BBC conversion.
Old Mar 22, 2005 | 03:03 AM
BubbaJJ's Avatar
BubbaJJ
Default About ready for a BBC conversion.
I have the short water pump, pulleys and accessory mounts. I have a set of headers for a 74 (mine is a 75, should work) and a Ron Johnson aluminum radiator. What else do I need? Should just bolt up at this point, right?
Old Mar 22, 2005 | 07:46 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Yep.
Some guys change the front springs, some don't. If you want, heavier front sway bar (7/8) I think, rear sway (5/16") bar. Just add engine and tranny. Maybe a new hood too, depends. Don't know about the '75 hood. I bought new poly motor mounts since there was a different listing for SB & BB. $60/pr.
Oh, and seat belts.
Here's a usefull site I didn't find until after the fact:
http://diabolicalperformance.com/c3bigblock.html
Old Mar 22, 2005 | 08:54 AM
norvalwilhelm's Avatar
norvalwilhelm
For years I kept the small block springs and really liked them. I also kept the original small block sway bar. I also had a 75 and the swap was a bolt in deal. no problems at all.
Old Mar 22, 2005 | 03:52 PM
BubbaJJ's Avatar
BubbaJJ
Thanks guys, I wasnt sure about the motor mounts. It sits high in the front as it is so I'll keep the springs the way they are in hopes that it levels out, may already have big block springs from the look of it. This is gonna be sweet!
To About ready for a BBC conversion.
