l82 or l48?
Old Mar 22, 2005 | 07:46 AM
PyroCricket414's Avatar
PyroCricket414
2nd Gear
Default l82 or l48?
is there any distinct way of telling which one i got? i have a 79 but i have no idea which engine it is. plz help if you can
Old Mar 22, 2005 | 07:54 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Check out the 5th digit in the vin. Engine Type: 8 = L48, 4 = L82
Old Mar 22, 2005 | 08:19 AM
page62's Avatar
page62
The tachometer has a 5500 rpm redline and an L82 logo on it.
Old Mar 22, 2005 | 08:42 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
But only the VIN will tell you what REALLy was there from Saint Louis Factory. All of the other things can be swapped and replaced.
Old Mar 22, 2005 | 08:52 AM
Stoge's Avatar
Stoge
On a '79, if the 5th digit in the VIN is a 4, then you have a factory L-82 car.
Old Mar 22, 2005 | 10:47 AM
kdf1986's Avatar
kdf1986
If it is the original block, then the vin number should also be stamped on the extension pad at the front of the passenger side head.
If that number matches the VIN number on the drivers side window pillar, then you can tell from the VIN number location if the original motor was a L82 or L48. From there you need to determine if anything else was replaced, but you will know if was originally a L82 or L48
kdf
Old Mar 22, 2005 | 08:28 PM
brooksman9's Avatar
brooksman9
My 79 L48 has a L82 tach and a motor from a 75 pickup. God only knows what else!
Old Mar 22, 2005 | 11:35 PM
cutlass44's Avatar
cutlass44
send away for your invoice that should clear up any doubts. I got mine a month ago, answered a few questions I had.
Old Mar 22, 2005 | 11:41 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
Now how do you know if it has a two bolt main or four bolt?
Old Mar 23, 2005 | 01:48 AM
Stoge's Avatar
Stoge
The way I understand it, all L82 engines are 4-bolt. I have read on here that most L48 are 2-bolt, but at times the factory was low on 2-bolt blocks and 4-bolts were used as a substitute.
Old Mar 23, 2005 | 08:34 AM
ruby76's Avatar
ruby76
but the only sure-fire what to tell is to drop the oil pan
To l82 or l48?
