Engine Installation
Old Mar 24, 2005 | 03:39 PM
glen242's Avatar
glen242
Default Engine Installation
Before I break anything, can the engine and standard transmission be installed as a unit on my '76? Rad is out but support is still in. I am mainly concerned with the transmission crossmember (non removable).
If yes, can it go in from the side or does it have to go in from the front?
Any other tips much appreciated.
Thanks,
Old Mar 24, 2005 | 03:44 PM
lars's Avatar
lars
Yes, it can go in as an assembly. As the tranny/engine feeds in, you just have to lift the tranny tailshaft housing up over the crossmember. It works fine.
Problem with going in from the side is that you don't have much movement fore/aft to feed the assembly in.
Old Mar 24, 2005 | 03:49 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Go in thru the front, engine and trans assembled together. Be sure your engine hoist is the cherry-picker type, with a looooong extendable support for the engine. And have a third person stand in front, watching how close the cherry picker gets to the nose of the front bumper.
Old Mar 24, 2005 | 03:50 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I dropped them together from the side. At that point I had everything else removed so I removed the core too. I later had to remove the drivers exhaust manifold and the fuel pump.
It would be a lot easier if you had someone under near the crossmember to guide the tailshaft. I didn't and it took me forever to line everything up while answering a ton of stupid questions.
Old Mar 24, 2005 | 03:58 PM
glen242's Avatar
glen242
Actually it is going in from a trolley hoist on my garage I beam. I have a plate that bolts to the carb mounting with 3 holes in in for hook placement or a load leveler type bar that bolts to who knows what. The load leveler has 2 chains at the end of an adjustable bar - you've seen the type. To use that bar I would have to hook up at diagonally opposite ends of the engine, I think. Which is the better way to go? If the leveler bar is the way, I would think you would want to hook up in a straight line rather than diagonal. Where would you bolt it to the engine?
Thanks,
Just checked and found that I did not get enough chain to go from side to side on the block, front and back. That was the problem with the load leveler.
So which is recommended, load leveler or the plate bolting to the intake?
Old Mar 24, 2005 | 06:59 PM
Z-man's Avatar
Z-man
By all means the load leveler...
Jughead - did you fill the transmission before you installed it? I'm assuming that this is the way to go and that the fluid won't leak out...
Old Mar 24, 2005 | 07:40 PM
jimcork1's Avatar
jimcork1
Default Fill Tranny
If you fill the tranny,, be sure to plug the tail housing spline at the rear seal or put the yoke in to keep it from pouring out.
Old Mar 24, 2005 | 08:46 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Yes, I did fill the tranny. Make sure you have the yoke push in. It has the tendency to slide out too, so watch.
How's that engine coming Jerry? Any new pics?
Old Mar 25, 2005 | 12:18 AM
glen242's Avatar
glen242
[QUOTE=Z-man]By all means the load leveler...
QUOTE]
OK, using the load leveler, where would I bolt the chains on either side front and back of the engine? I'm paranoid about bolting into aluminum and I have aluminum heads and intake.
Thanks,
Old Mar 25, 2005 | 01:48 AM
Z-man's Avatar
Z-man
Thanks,
I used the holes in the heads. Aluminum is plenty strong. You can spread the load by using two in front and two in back. Look how Jughead set his up.
Jughead - no new pics. Just doing small stuff in the engine compartment and other boring stuff like running the fuel lines. Soon, however, better things...!!
To Engine Installation
