Fast Idle question..
Old Mar 28, 2005 | 10:47 AM
Rhufus's Avatar
Rhufus
Default Fast Idle question..
My '78 L-48 fast idles @ 1500 RPM. I really don't need it to idle that fast. How can I slow it down without "screwin" something else up?
Thanx
Old Mar 28, 2005 | 11:07 AM
lars's Avatar
lars
Back off the fast idle screw and set it where you want it. That won't affect anything else.
Old Mar 28, 2005 | 11:11 AM
74FLCONV's Avatar
74FLCONV
If my car hasn't been run for awhile, the "kick-down" for the fast idle doesn't release. I have to stick my fingers in the linkage and manually release it. This linkage is on the passenger side of the carb, buried behind the choke.
This may be your problem. What carb are you running? Mine is the Edlebrock replacement for the Q-Jet. I had the same problem with the original Q-Jet.
D. Ocean
Miami, FLA
Old Mar 28, 2005 | 02:08 PM
rihwoods's Avatar
rihwoods
Thanx
No comprende ? Do you "kick it down" after warm up ? Need clariifcation.
Old Mar 28, 2005 | 02:34 PM
Rhufus's Avatar
Rhufus
I'm running the original Q-Jet. It does kick down after warm up. The problem is pipes and the "be a good neighbor thing".
Just don't need it idling @ 1500 RPM's.
Old Mar 28, 2005 | 09:04 PM
rihwoods's Avatar
rihwoods
That may be a reason to adjust your "fast idle".We are only talking five minutes of warm up.In Calif they allow 95 decibels for performance exhaust.What they allow in your state ? Mine "fast idles" at 1500 rpm at probably 85 decibels or so.No big deal.
Old Mar 28, 2005 | 10:49 PM
lars's Avatar
lars
Just back off the fast idle screw about a half turn and get your idle speed down around 1000 -1200. It takes 4 seconds to give the screw a twist once you can see it. I agree 1500 is a bit fast - you don't need it that high, and that's a lot higher than spec. I set up most of the carbs I do to about 1000-1100 on the fast idle.
Old Mar 29, 2005 | 03:26 AM
Turbo-Jet's Avatar
Turbo-Jet
Does the throttle pedal follow the fast idle setting? ie: if on the high step the throttle blades will be held open off the regular stop and the pedal will not spring back as far?
Sounds right, but I've never actually noticed this before.
Old Mar 29, 2005 | 08:30 AM
lars's Avatar
lars
Yes, but it's such a small amount (about 1/16") that I'd doubt you'd notice it.
To Fast Idle question..
