Intake Manifold Question
Old Mar 30, 2005 | 10:32 AM
77BuffaloVet's Avatar
77BuffaloVet
Default Intake Manifold Question
I just put a non-EGR Performer Intake on my '77. There is a manifold port under the water neck on the front driver's side. What is it for?
Old Mar 30, 2005 | 11:15 AM
Sarge81's Avatar
Sarge81
If it's a threaded opening. It's probly for a ported/thermo vacuum switch. Emission junk. Or does it go through to the coolant passage under the thermostat opening? Could be for a coolant bypass hose. Can you post a pic of it?
Darryl
Old Mar 30, 2005 | 11:23 AM
77BuffaloVet
Thank you for the reply...
I can't post a pic right now...It is a threaded port and I do belive that it connects to the water passage. The heater hose is on the passenger side of the manifold, so it is not that. If it is a water port, what would it be for? If I don't need it, what should I use to plug it?
Any help would be great!
Thanks,
Chris
Old Mar 30, 2005 | 11:49 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I agree with Sarge on this one... I think it's a thermal switch for the emissions stuff...
Old Mar 30, 2005 | 12:44 PM
marshrat99's Avatar
marshrat99
If it's about 3/4" then just run in a pipe plug. Or you can use it to relocate your water temp sending unit.
Old Mar 30, 2005 | 01:35 PM
Paul L's Avatar
Paul L
Waterpump bypass.
Old Mar 30, 2005 | 04:51 PM
fast idle's Avatar
fast idle
I just put a pipe thread plug in mine.
Old Mar 30, 2005 | 05:27 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
I put my temp sender in it since the threaded hole in the new head was too small.
To Intake Manifold Question
