Dist end play
Old Mar 31, 2005 | 12:54 PM
Fevre's Avatar
Fevre
Default Dist end play
I ordered a new dist and the end play was about .035" which I believe is too much so I asked them to send me a new one, new came with same end play. This is an alum housing computer controlled dist, so how much end play should it have? I keep seeing .012-.015" as a rule of them for alum dist.
Old Mar 31, 2005 | 01:08 PM
lars's Avatar
lars
Optimum is .004" - .007". Get Moroso shim kit part number 26140 and shim it yourself - very few distributors will be in tight spec on the endplay. The MSD distributors are the only ones I've seen with tight end play.
Old Mar 31, 2005 | 01:10 PM
Tom454's Avatar
Tom454
Old Mar 31, 2005 | 01:17 PM
Fevre's Avatar
Fevre
Thanks guys
Old Mar 31, 2005 | 06:52 PM
VETDRMS's Avatar
VETDRMS
My MSD pro-billet is .013" I am going to shim it down to .007.
Old Mar 31, 2005 | 10:23 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Endplay is just the opposite of foreplay.
Endplay is either when u wake up and see what ur sleeping with and need to leave without waking her up. Or unless she's in ur bed then u want to get her out of the house before anyone u know recognizes u together.
Now if ur home alone it could have an entirely different meaning but never mind going there.
But for the distributor i never have seen a spec so i just shimmed it to remove any end-play but still turn smoothly without drag. This has worked fine for me.
Incase u mean or would like to know side to side spec - less than 0.010" where 0.001" the best (and 0.010" worst) between reluctor and pickup - this is with dist out of car of course. cardo0
Old Apr 1, 2005 | 11:17 AM
Fevre's Avatar
Fevre
Guess .035 is fine with whom ever makes them for summit cuz they sent me another one with the same play. I am going to pull the shim from one and put it in the other and see where I am, will send one back missing a peice.
To Dist end play
