I am in the process of rebuilding a tach drive distributor for my 71. The vacuum advance that was on there is stamped "437 15". I can't find my copy of your vacuum advance paper to look it up. I do have a "B 26" I could us in its place.
What would you recommed? I believe I have a NAPA "VC 680" installed in my existing distributor.
Also I noticed the advance posts on the plate attached to the points cam are worn. It is stamped "718 CCW" Do you know if these are available from NAPA? Suggested part number?
Mike -
The cam plate is not available from any source that I am aware of. I have replacement posts if you have the ability to un-braze your existing posts and re-braze the cam plate with my new ones. Let me know.
The choice of vacuum advance control unit depends on the camshaft in the engine and the vacuum level you pull at idle. For mild-cammed engines following close to stock specs, I recommend using the VC680 (stamped B1). This unit pulls in 16 crankshaft degrees of advance at 16 to 18 inches of vacuum. If you have an engine/cam combo that pulls a bit less than that much vacuum, use the VC1810 (stamped B28). This unit will pull in its full range of advance below 10 inches of vacuum. A mid-range unit that is very popular with aftermarket distributor manufactuirers for use with mildly hopped-up street engines is the VC1808 (stamped B26). This unit also pulls in 16 degrees of advance, and does so at 11 inches - a nice performance unit. The B26 is a great all-around performance unit, so I would use it if I were you (depending, of course, on your cam).
I wanted to resurrect this thread to ask Lars his recommendation for "fast-burn" heads. My guess from articles I have read on vortec heads is to reduce the max mechanical advance from 36* to 34* and max with vacuum from 52* to 50* That means keep the same vacuum can and just turn the distributor back 2 degrees. What do you think? Joe
The fast-burn heads seem to produce best power between 32 and 34 total, and max combined total with vacuum advance pulled in along with the full mechanical should be about 50. You can get there by simply backing off the timing, but this also reduces your initial. If you have a bit of a cam, you're going to want to keep a bit of initial timing in it to obtain a good idle and snappy off-idle throttle response, which means you may have to shorten the advance curve in order to keep an adequate amount of initial timing while limiting the total to 32-34.
Wow - that posting of the article really sucks - the formatting for the tables is all jumbled. If anyone wants a "real" copy of the article, be sure to drop me an e-mail request and I'll send you an MSWord version that is usable and readable.
