Brakes Broken
. Started bleading brakes and was not getting fluid out the front.
I started the car to see if booster would help and both back main steel brake lines ruptured just under the drivers door. Guess its better in the garage than on the road. So.... my question is has anyone replace the steel lines that follow the frame from the proportioning valve? Might as well do the fronts while I'm at it. Looking for some advice. And would you buy preformed or bend your own? Im am hoping to actually drive this car some day.
Anyway, the main line to the rear can be changed with the body on. It's a little tough getting some of the retaining clips on. Mine was a 76 and the brake line was also run along with a gas/vapor line. I would not suggest installing it in sections, get the right length or order a direct replacement.
If you are considering replacing sections using fittings & couplers, remember all lines have to be "double flared" or "inverted flared" to be legal (and safe). This requires a double flaring tool and a little skill. If you don't follow the rules on this & get in an accident due to a ruptured line or flare.... you will be liable.
a full set fo stainless lines. I bought the set from ZIP.
The long line was bent almost perfectly - except that they
need to bend it in half to ship. No problem - it straightens out fine.
This way, the brake lines will outlive me. I don't ever want to
change them again.
Ok - they aren't cheap, but not much more than a steel set.
I bent my own fuel lines, but I feel much better going stainless on the brakes.
change them again.
Go a full set of pre-bent stainless lines. Since one line ruptured...the rest are sure to follow. Safety systems are NOT things to go cheap on.
Just my $.02
