Hurst Shifter Install
Old Apr 1, 2005 | 12:10 PM
lvrpool32's Avatar
lvrpool32
Default Hurst Shifter Install
Who has a hurst shifter on their 4 speed? I am curious as to how you attached the actual shifter to the transmission? Direct bolt on? If so, then how did you attach the 2 piece shifter mount/trans mount bracket??
cheers,
Nick
Old Apr 1, 2005 | 12:28 PM
lars's Avatar
lars
The Hurst shifter comes with its own bracket/plate that bolts to the existing shifter hole pattern in the side of the tranny. The shifter then bolts to this plate. The Hurst shifter does not attach to the tranny mount.
Old Apr 1, 2005 | 12:32 PM
GTR1999's Avatar
GTR1999
This should help Nick, Hurst Comp+ mounted to a '69 M-20
Gary
Old Apr 1, 2005 | 12:35 PM
lvrpool32's Avatar
lvrpool32
thats cool...but how does the tranny mount to hte cross member??
Old Apr 1, 2005 | 12:38 PM
GTR1999's Avatar
GTR1999
There is a rear rubber mount with 2 bolts to it right under the speedo cable connector on the tailhousing. The crossmember has 2 holes to access them from under the car.
Gary
Old Apr 1, 2005 | 02:16 PM
lvrpool32's Avatar
lvrpool32
Thanks Gary, I see your shifter is kicked back in a reclined position, is that the preffered position?? Mine is in the straight up right now...
Old Apr 1, 2005 | 04:38 PM
GTR1999's Avatar
GTR1999
To be honest Nick that's the only way I ever had it mounted? Not sure it will fit the console otherwise?
Gary
Old Apr 1, 2005 | 04:41 PM
lvrpool32's Avatar
lvrpool32
I guess it just looks different as mine is a T-10.
thanx for the help
Old Apr 2, 2005 | 03:21 AM
71coupe's Avatar
71coupe
I moved my shifter back about 4". I heated the shifer up with a torch just below the shifter boot area. It's more comfortable now as I no longer need to reach as far.
Old Apr 2, 2005 | 07:25 AM
Gordonm's Avatar
Gordonm
Before my TKP swap I had a Hurst in mine. It did sit back but if Itried to move ot more forward it would hit the console is 1st and 3rd gears. Mine was centered left to right just had to move it to a more "reclined" position so it would not bump the console.
To Hurst Shifter Install
