When I lived in Charlotte, NC I found a machine shop that rebuild vortec heads. He had several pairs in stock. I paid $400.00//pair. This included new Z-28 springs, used but clean valve covers and used self aligning rocker arms. I reused my pushrods, cam and lifters. I was already in need of a new intake. You nmay want to consider looking for used but rebuilt vortecs in your area.
You can shop around and get pieces from different sources. You wind up saving some cash that way. Ebay is always a source as there are some good deals there, just make sure you know you need and check their rating.
There are some places like Scoggin Dickey, Salle, Pace, Jegs, that have fair prices that will get you in that price range.
Price of the above is $1090 and includes gaskets. Check around and you should be able to find a nice set of centerbolt alum valve covers for $40-60. That puts you at $1150, the former $1100 was not including gaskets. The above items were randomly picked. Shop around and you should be able save.
What springs do i need to to get .488 to work please specify. Someone said they drop right in right. Anything else i need to do. Lucky me i'm pulling these heads and intake off my bros car so i only had to pay for the cam. Thats almost a free mod.
Im sure this replacement goes differently with different people..i sure dont expect everything to go in perfectly..wouldnt mind if it did tho. I guess all i can do is pray huh..
I see that many of you have already done the Vortec replacement, but do any of you have numbers..such as track times..dyno numbers..video or sound clips...etc...
I've been doing some research and this is a little off topic to the Vortec question at hand but this seems to be THE place to discuss heads currently.
OK, so I compared the Vortecs to the Summits to the Sportsman II heads and with the price I'm seeing for assembled Sportsman heads at about $400 each, why no discussion on the Sportsman? They have a huge intake runner (220cc), upsized 2.02/1.60 valves, and excellent lift. The Summits are about the same on valve size and lift but the intake runner is puny at 165cc (vs 220cc on the Sportsman and 175cc on the Vortec). The Vortecs modified to have the extra lift are about the same price as a pair of Sportsmans but you don't get the larger valves or intake runner.
So, what's the experience with Sportsman II heads? Vizard swears by these heads in his book on budget small block performance.
Big intake runners are good at high rpms, because they flow better -- good if you race or like to go over 5000 rpm on a regular basis. Smaller runners provide good midrange power and quick responsiveness -- good for a driver where midrange torque is important. The bottom line is that you want to choose the best head for your application.
...OK, so I compared the Vortecs to the Summits to the Sportsman II heads and with the price I'm seeing for assembled Sportsman heads at about $400 each, why no discussion on the Sportsman? They have a huge intake runner (220cc), upsized 2.02/1.60 valves, and excellent lift. The Summits are about the same on valve size and lift but the intake runner is puny at 165cc (vs 220cc on the Sportsman and 175cc on the Vortec). The Vortecs modified to have the extra lift are about the same price as a pair of Sportsmans but you don't get the larger valves or intake runner...
The Vortec head have the advantage depending on the application. At 170cc intake runner with the excellent flow they have 230 cfm @ .500 lift, they are the best street heads that you can get for under 400-425 hp. The little intake port give great torque from 2000 rpm with a moderate cam. If you want 450-500 hp, then the 220cc sportsman would be a better choice probably.
For the spring question, I installed Scoggin-Dickey .550 inch lift spring that goes right in with no machining what so ever. You just have to remove the internal damper or second spring. The stock clearance from the top of the guide seal to the bottom of the valve retainer was .525 to .535 inch on all valves. I run a .500 inch cam with no problem. I installed screw-in stud for safety.
I ran 300 rwhp last summer with 13.30 @ 108 mph on street tire and 3.54 rear. With more tweaking, I hope to be close to 13.00 and 320-30 rwhp since I have a manual trans with a 4 degrees retard on my cam.
Stephan
I'm confused. How does a SMALLER runner improve torque? I thought it was all about the flow into the chamber and the mixture of the gas to air. In which case the better flow regardless of rpm should provide a better mixture and better torque leading to hp. Of course given all things are equal in comparing with the chamber, valve size, etc.
Low end torque is the result in part of greater airflow velocity at low rpm. It's like blowing through a small straw and the same through a big straw. The air goes a lot faster with the small straw with the same pressure. So the cylinder fills faster at low rpm because of the higher velocity of the air giving more torque and hp.
The little 175cc Vortecs still outflow them in this comparison. The Vortecs cost about $460 for the pair, a considerable savings. The outflow everying in the category 1 class (under 180cc) including all the aluminum heads they tested. They out flow, or are close to, most of the heads in the next category.
I would not recommend them. By that I mean I have not used them and I am unsure about correct fitment. You would have to talk to Scoggins to see if they recommend them as a replacement.
Here is what I found in regards to the springs for the stock head and springs. Valvespring Seat: 1.300” O.D., 0.850” I.D Valvesprings: Single wire with damper 1.235” O.D., 0.875” I.D. 75-pound seat pressure @ 1.700” installed height Coil-bind @ 1.150”
The ones from Scoggins: Single Valve Spring has an outer diameter of 1.32".
This spring is .020" bigger than the Vortec pocket. A little work may be required.
Another option is to use Crane Cam’s 10309-1 drop-in valve spring and retainer kit which is good for .550” lift with no machining. The downside to this is $$. The cost is in the range of about $150 or a little more.
Here is the specs: Outside Diameter of Outer Spring (in): 1.255 Inside Diameter of Spring (in): 0.870
Spring Rate (lbs/in): 409
As you can see, this spring it the same dimension as the stock spring and will drop in.
From: I can explain it to you, but I can't comprehend it for ya.
JDRez42,
Those are the exact springs I used in both sets of Vortec heads that I've set-up. On the first set, the springs dropped right in with no modifications at all to the spring pockets or towers.
On the second set, the spring pockets had to be openned up just a bit so, I guess it will just depend on the individual heads. Still, having the spring pockets opened is no big deal for the machine shop.
Notice that both these springs are 1.25 dia. where the LT4 springs are 1.32 Dia. If you use the Z28 springs just make sure they clear the spring towers. I would much rather open the pockets up a bit for the bigger springs that shave the spring towers for the smaller springs to set down in the pockets. Not sure if one way is better or not, just my preference.
I think any of the three of those springs will suit you well.
I don't have any expereince with the Z28 springs in Vortec so I can't comment on em, but I did set up a set of 882's for my brother-in-laws suburban with the .490 max lift Z-28 springs and they seem to work fine.
Are the intake gaskets reusable. I took the vortecs off my bros engine and the intake gaskets are really solid like plastic with an embosed silicone bead. It had a edelbrock performer(vortec) manifold. Do i need to replace those gaskets? Also does anyone know what kind of CR increase there will be compared to my '80 heads.
Yes the gaskets are reuseable, if they look to be in good shape, I would use em. Don't forget when you are installing the intake manifold, the torque specs are 11 lbs on the intake bolts. (yes 11 lbs). I went to the local chevy dealer and picked up a set of factory intake bolts for 96-98 truck with Vortec heads. The bolts are a specific lenght designed to bottom out in the heads to prevent overtightening the intake.
And, as far as the compression increase, the Vortecs are advertised as 64cc chambers. But at the machine shop I deal with they said everyone they've ever cc'd came out at 61-62 cc's. I'm not sure what heads you have now, but more than likely they are 76cc, so yes, you are gonna bump your compression a little, maybe a couple of points.
The L48 cam should be changed along with ANY head swap. It barely pushes the valves open...
The L82 cam is pretty good (it's the same as the one in the 350/350 engine of the late '60s). It can be used with new heads, although some folks like the swap it out for a more "modern" grind.
