Flywheel strength? Pics
Old Apr 2, 2005 | 08:16 PM
Jclgodale3's Avatar
Jclgodale3
Default Flywheel strength? Pics
Update...flywheel is 4340 STEEL not aluminum. Still need to know of any problem with this machining...
Ok...so this aluminum flywheel, using the stock flywheel bolts, caused a slight interference with the springs on the flywheel side of the clutch disc. I took the flywheel to a machine shop and had them take 3/16 of an inch out of the bolt area (in red) to allow the springs on the clutch disc to clear the bolt heads on the flywheel. Is there a concern as far as strength or integrity of the flywheel in your opinions? Please advise. I have started at the ran the car up to about 3000 rpms but the car has not been driven to to the body sitting next to it...
Old Apr 2, 2005 | 08:27 PM
vettepilot68's Avatar
vettepilot68
Well, my neighbor and I had some concern, but it aint nothin' compared to the problems the chunk out of the 12 o'clock position is going to cause. might need some kinda counterweight at the 6 o'clock position...LOL.
Old Apr 2, 2005 | 08:38 PM
Jclgodale3's Avatar
Jclgodale3
hey! That was the only way to balance it! JK. Did that to cover the trademark name
Old Apr 2, 2005 | 08:40 PM
Sharky Guam's Avatar
Sharky Guam
3/16 is alot to remove. How much is left? What kind of clutch is it?
Old Apr 2, 2005 | 08:44 PM
Jclgodale3's Avatar
Jclgodale3
I would say 1/4 to 3/8 inch left without actually measuring. Stock OEM clutch, not planning any hard core driving
Old Apr 2, 2005 | 09:15 PM
b71vette's Avatar
b71vette
Default Way to Risky for me
So you basically machined away 1/3 of the flange. I would put a scatter shield on if it was me. Not an area you want to mess around with.
Good Luck
45ACP's Avatar
45ACP
That is the last place I would want to remove material from.
Old Apr 2, 2005 | 10:36 PM
Solid LT1's Avatar
Solid LT1
I would say if it is better than 1/4" thickness left that you are OK. I wonder why the disc interfered to begin with? Are you sure you are installing the disc in the correct direction? The small retainer plate that captures the springs in the center hub should always go towards the transmission side. You said the flywheel is aluminum but, I don't see any steel friction surface on the face of the flywheel. The clutch disc will tear the heck out of an aluminum surface if thats what it is made out of. I wonder, is the flywheel a "Ebay Special" made in China part. I use the 67-9 L-88 14lb nodular iron flywheel in my Vette and have used them for years and always been happy with them. Maybe you want to consider pickin one up at GM Parts Direct.com for your Vette. I hate the transmisson removal job myself and want to do as little as possible. Good Luck, Eric B.
Old Apr 2, 2005 | 10:57 PM
Jclgodale3's Avatar
Jclgodale3
SolidLt1...yep, I am sure the disc was facing the right direction (smallest flanges forward) The springs "just caught" the bolt heads. Installed backwards would have been even more of an issue! So...how much are we talking for the one you are describing? The nodular one...
Old Apr 2, 2005 | 11:08 PM
Sharky Guam
Yep, that is a little much. And if it is hitting, chances are that it is a used part that already has been turned down. IS it new or did you get it used? I would not chance using it. What would happen if it let go? Nevermind, I do not want to know......
Consult the clutch manufacturer and see what he thinks. I think that somehow the parts are mismatched if the clutch and flywheel are new.
Old Apr 2, 2005 | 11:12 PM
Jclgodale3's Avatar
Jclgodale3
Sharky and anyone else who has responded...I stated this was an aluminum flywheel...I was wrong. It is made from 4340 Steel. Will this make a difference? As far as strength? Oh...and it is a new flywheel
Old Apr 3, 2005 | 01:58 AM
Jclgodale3's Avatar
Jclgodale3
ttt
Old Apr 3, 2005 | 08:42 AM
redvetracr's Avatar
redvetracr
hope you are running a scattershield.....
...redvetracr
Old Apr 3, 2005 | 10:05 AM
vettepilot68
I think the jury is in...I'd change it.
Old Apr 3, 2005 | 11:29 AM
69monzaredbigblock's Avatar
69monzaredbigblock
Could the problem be with the bolts being used? Wrong bolts, maybe too many washers under the heads? Just a thought.
Old Apr 3, 2005 | 12:38 PM
Jclgodale3's Avatar
Jclgodale3
nope...brand new bolts...1 star washer under each head...and correct bolts for a manual flywheel. I guess now I'm leaning towards changing it out before I set the body back on. Waste of a good, new steel flywheel I guess. Any suggestions for a good one to use?
Old Apr 3, 2005 | 12:52 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
How about uncovering that trademark name so that we can find out who makes this thing?
Do you have a part # for it?
Dep
To Flywheel strength? Pics
Old Apr 3, 2005 | 01:04 PM
Jclgodale3's Avatar
Jclgodale3
it's an ASI
Old Apr 3, 2005 | 02:04 PM
LFZ's Avatar
LFZ
Old Apr 3, 2005 | 02:21 PM
Jclgodale3's Avatar
Jclgodale3
Originally Posted by Redshark6974
your with stupid? or you agree?
