Carb? Problems (Rochester)
Old Apr 4, 2005 | 11:47 PM
corvettecris's Avatar
corvettecris
Default Carb? Problems (Rochester)
When I drive my 69 (350/300 automatic) It runs really well, and idles at about 900 RPM, but it likes to die if you accelerate and then let off of the pedal. As it begins to slow down in it's coast, especially once you stop at a sign or light, it will often just die. It seems worse when the engine is warm, as opposed to cold.
It has the original engine, and runs really well, but I wonder if the carb needs some adjusting, or a rebuild?
Old Apr 5, 2005 | 12:17 AM
Sharky Guam's Avatar
Sharky Guam
Have it rebuilt...symptoms indicate that it is leaking.....
Old Apr 5, 2005 | 12:21 AM
corvettecris
Have it rebuilt, or can I rebuild it?
Leaking what, fuel? Vacuum? Something else weird?
Old Apr 5, 2005 | 09:38 AM
1974slcvette's Avatar
1974slcvette
You should be able to rebuild it. I just did mine a couple of weekends ago. It took me 1 day to remove, clean, rebuild and remount. It is a fairly straight forward job. I bought the rebuild kit at Autozone, but NAPA carries them as well. The instructions included with the kit were excellent. Make sure you buy a new float, as it is not included with the kit (thats one of those 'While I'm here' items).
Oh, and your carb could be leaking fuel or air. If your not smelling or seeing gas, it is probably a air leak.
Good luck
Old Apr 8, 2005 | 12:25 AM
corvettecris
Thank you. I'm assuming I will need some part numbers off of the carb to get the correct kit? Are they the ones near the choke tower?
Old Apr 8, 2005 | 12:53 AM
1974slcvette
Yes. Should be a 7029202 carb (69 350/300, auto). Easiest way though is to just tell the parts store the year and engine size and that should do it.
Old Apr 8, 2005 | 01:03 AM
corvettecris
Thanks a bunch!
To Carb? Problems (Rochester)
